service-module...?
saidfrh
A 1700 router, ver 12.3(22) does not accept the following commands under int s0 . Any suggestions would be appreciated to configure the router.
Thanks.
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
service-module t1 timeslots 1-24 speed 64
service-module t1 fdl both
Said
For some cards those commands are done with service-module commands under the serial interface and for some they are done as commands under the controller. What kind of card is in the router that you are attempting to configure?
Rick
Rick
paolo bevilacqua
You might need an IPOS upgrade, which exact hardware do you have, please send "show diag".
Rick
Rick
Rick,
After posting the question, I realized it could be the WIC card. I am using a serial WIC card on the 1720 series router to test the point-to-point configuration on the router with a 2612 router with serial WIC card. The production router has a RJ45 WIC interface. The commands were accepted by the production router.
Thanks.
Said
sh diag
Slot 0:
C1720 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.1
PCB Serial Number : JAD05510M9Z
Part Number : 73-3201-06
Board Revision : A0
Fab Version : 04
Product (FRU) Number : CISCO1720
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 B2 41 06 01 C1 8B 4A 41 44 30 35 35
0x10: 31 30 4D 39 5A 82 49 0C 81 06 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC/VIC Slot 0:
--More-- Serial 1T
Hardware revision 1.0 Board revision M0
Serial number 0030806045 Part number 800-01514-01
FRU Part Number WIC-1T=
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 02 01 00 01 D6 10 1D 50 05 EA 01 00 00 00 00
0x30: B0 00 00 00 03 11 08 01 FF FF FF FF FF FF FF FF
