Service-policy input / service-policy output
muca
Level 3
Level 3
I am a bit confused about input and output service-policy so just wondering if the way I understand it is correct.
Let say we have a connection between two locations
R1 --wan--R2
R1 has the following configuration
int fastethernet0
service-policy output marktraffic
int serial0
service-policy output marktraffic2
First question
Packets to R2 (R1->R2) would be marked according to the serial interface policy marktraffic2 and packets from R2 (R2->R1) would be marked according to fa0 marktraffic1 policy. Is that correct?
Second question
Now, let's say I have this config
interface fa0
service-policy input marktraffic
int serial0
Packets going to R2 (R1->R2) would be marked with the policy marktraffic on the
fa0 interface but then would be remarked again using marktraffic2 policy on the serial interface.
No packets would be marked coming from R2. Is that correct?
Thanks a lot.
andrew.prince
Level 10
Level 10
First Question - No. Packets leaving the s0 interface on R1 going to R2 will be marked. Any packets LEAVING R1 FA0 onto the LAN will be marked - not entirely just from R2.
Second Question - Yes.
HTH>
Thanks Andrew
Regarding question 1
What will be marking packets coming from R2 onto R1 lan will be the:
int fastethernet0
not
int serial0
Is that right?
If I just had the interface serial0 output police on R1 would packets coming from R2 onto the R1 lan also be marked?
Joseph has given you all the information!
Joseph W. Doherty
Andrew has answered your quesitions, but if you wanted to mark traffic to/from R2 on R1, you might:
int serial0
I.e., you can have both an in and out policy on an interface.
