Hi Guys,
I have a issue with my router for service-policy. I am limiting bandwidth to 9Mbps but traffic goes above 9Mbps and ACL counters do not increase.
Tested this with another exact same model router with same IOS and config it works but does not work on the previous router. Both routers have same IOS and are same model
Below is version of both the routers
(c7600s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)S
Config are as follows
class-map match-any 9216K-Inbound
match access-group name IT-9216K-InBound
class-map match-any 9216K-Outbound
match access-group name IT-9216K-OutBound
policy-map IT-9216K-Policer-Inbound
class 9216K-Inbound
police rate 9216000 bps burst 1728000 bytes
conform-action transmit
exceed-action drop
policy-map IT-9216K-Policer-Outbound
class 9216K-Outbound
exceed-action drop
ip access-list extended IT-9216K-InBound
permit ip 103.4.17.0 0.0.1.255 any
permit ip 103.4.17.0 0.0.0.255 any
ip access-list extended IT-9216K-OutBound
permit ip any 103.4.17.0 0.0.0.255
interface GigabitEthernet0/0.315
description TEST
vrf forwarding IT
encapsulation dot1Q 315
ip address 103.4.17.209 255.255.255.252
service-policy input IT-9216K-Policer-Inbound
service-policy output IT-9216K-Policer-Outbound
