11-11-2017 09:21 PM - edited 03-05-2019 09:28 AM
I would like to find out and understand more. If i create:-
ACL:
Extended IP access list ACL_TEST_INBOUND
10 permit ip any host 10.10.10.x
20 permit ip any host 20.20.20.x
100 deny ip any any
Class-Map:
Class Map match-any CM_TEST_INBOUND (id 1)
Match access-group name ACL_TEST_INBOUND
Policy-Map:
Policy Map PM_TRAFFIC_LIMIT_INBOUND
Class CM_TEST_INBOUND
police cir 20000000 bc 62500
conform-action transmit
Apply to interface:
interface Vlan5
description IF_TEST_INBOUND
ip address 100.100.100.1 255.255.255.0
service-policy input PM_TRAFFIC_LIMIT_INBOUND
Only the bandwidth for hosts from ACL_TEST_INBOUND, 10.10.10.x and 20.20.20.x, will be affected? Say if I have host 30.30.30.x, the incoming bandwidth will not be affected by the service-policy. Am I right to say that?
Thanks in advance.
Solved! Go to Solution.
11-11-2017 09:48 PM
Yes you are right. You are dropping traffic over 20mbps towards 10.x and 20.x. Nothing else should be affected by this command.
11-11-2017 09:48 PM
11-11-2017 09:53 PM
Hi M.G,
Thanks!
