Services Limitation - Block Torrent traffic
batumibatumi
Hi All,
I want to configure service limitation for torrent traffic, i did the configuration but anyway it is not working. I mean, when i am trying to download files from torrent software, it is still downloading, please see attached!
I am using Cisco Router 2901 with IOS version - c2900-universalk9-mz.SPA.154-3.M2.bin
I have done the following configuration:
class-map match-all torrent
 match protocol bittorrent
class-map match-all torrent1
class-map match-all SASA
 match protocol gnutella
policy-map SERVICE.LIMITATION.FROM.WAN
 class torrent
  drop
class SASA
  drop
policy-map SERVICE.LIMITATION.FROM.LAN
 class torrent1
  drop
 class SASA
  drop
interface GigabitEthernet0/0
 description Outside
 ip address 10.48.x.y 255.255.255.0
 ip access-group VOIP in
 ip nbar protocol-discovery ipv4
 ip tcp adjust-mss 1350
 load-interval 30
 duplex auto
 speed auto
 service-policy input SERVICE.LIMITATION.FROM.WAN
end
interface GigabitEthernet0/1
 ip address 192.168.x.y 255.255.255.0
 ip flow ingress
 duplex auto
 speed auto
 service-policy input SERVICE.LIMITATION.FROM.LAN
end
Thank you in advance!
batumibatumi
Guys, do you have any ides how to solve this issue?
It might be because Bittorrent traffic is encrypted and therefore NBAR is not able to recognize it. I see a solution suggested here: https://supportforums.cisco.com/discussion/10796856/nbar-bittorrent-and-rc4-based-encryption
Hope this helps,
Jose.
Hi Jose,
First of all, Let me thank you for your suggestion, let me check it and i will post the result a bit later.
Best Regards,
Jose,
I am using NBAR version of 20. there is activated 42 protocol, i mean, NBAR can check all this ports. it also includes lot of ports like :
 Last clearing of "show ip nbar protocol-discovery" counters 1d08h
                            Input                    Output
   bittorrent        8850                     2288
                       980546                   132796
HQ-C2901#sh ip nbar protocol-id
Protocol Name             id            type
bgp                      179           L4 IANA
bittorrent               69            L7 STANDARD
HQ-C2901#sh ip nbar port-map bittorrent
port-map bittorrent               udp 3724
port-map bittorrent               tcp 3724 1080 6969 6881 6882 6883 6884 6885 6886 6887 6888 6889
HQ-C2901#sh ip nbar protocol-pack loaded detail
Loaded Protocol Pack(s):
Name:                            Standard Protocol Pack
Version:                         1.0
Publisher:                       Cisco Systems Inc.
NBAR Engine Version:             20
State:                           Active
Modules:
1   base                             Mv: 4
2   ftp                              Mv: 4
3   http                             Mv: 17
      Iv:                              irc - 2
4   static                           Mv: 6
5   secure-http                      Mv: 4
6   netbios                          Mv: 1
7   socks                            Mv: 2
8   nntp                             Mv: 2
9   tftp                             Mv: 2
10  exchange                         Mv: 3
11  vdolive                          Mv: 1
12  sqlnet                           Mv: 2
13  netshow                          Mv: 3
14  sunrpc                           Mv: 3
15  streamwork                       Mv: 2
16  citrix                           Mv: 13
17  fasttrack                        Mv: 3
18  gnutella                         Mv: 7
19  kazaa2                           Mv: 11
20  dhcp                             Mv: 1
21  rtsp                             Mv: 9
22  rtp                              Mv: 8
23  mgcp                             Mv: 2
24  skinny                           Mv: 3
25  h323                             Mv: 1
26  sip                              Mv: 4
27  rtcp                             Mv: 4
28  edonkey                          Mv: 6
29  winmx                            Mv: 5
30  bittorrent                       Mv: 5
      Iv:                            socks - 2
31  directconnect                    Mv: 4
32  imap                             Mv: 1
33  pop3                             Mv: 1
34  irc                              Mv: 2
      Iv:                             http - 17
35  smtp                             Mv: 1
36  dns                              Mv: 1
37  skype                            Mv: 5
38  sap                              Mv: 1
39  pptp                             Mv: 1
40  ntp                              Mv: 1
41  iana                             Mv: 1
42  custom-protocols                 Mv: 1
