set authentication on an interface on router ospf
ciscomoderator
Community Manager
Community Manager
We received this question from our CSC Facebook community
http://www.facebook.com/CiscoSupportCommunity
Arshia Enayati I need help.....
how I can set authentication on an interface on router ospf (area 0) not whole interfaces on area...
Mahesh Gohil
Level 7
Level 7
Below is the process by which you can enable authentication on interface..same process to be repeated on far end also
interface GigabitEthernet3/0
ip address 100.100.100.1 255.255.255.252
ip ospf authentication-key cisco123
negotiation auto
interface GigabitEthernet1/0
ip address 125.62.167.1 255.255.255.252
ip ospf authentication null
negotiation auto
router ospf 100
log-adjacency-changes
area 0 authentication message-digest
network 100.100.100.0 0.0.0.3 area 0
network 125.62.167.0 0.0.0.3 area 0
but this way gig1/0 (every interface that is part of area 0) will also pass through authentication process and it will fail to estlablish adjacency. To bypass that interface you need to have below command on interface level.." ip ospf authentication null"
negotiation auto
hope this is helpful
Mahesh
The precise answer to the question would be to configure the following under the interface:
interface
ip ospf message-digest-key 1 md5
ip ospf authentication message-digest
This will enable md5 authentication only on the desired interface and not the entire area.
Atif
