set/match ip dscp vs. set/match dscp
mlitka
Level 2
Level 2
Is there any difference between these two commands:
set ip dscp and set dscp
match ip dscp and set dscp
It appears that you can mark using one ore the other but not both, but match using both.
For example
class-map bulk
match dscp af11
match ip dscp af11
class mark-bulk
set dscp af11
or
class mark-bulk
set ip dscp af11
mohammedmahmoud
Level 11
Level 11
Effective with Release 12.2(13)T, the set ip dscp command is replaced by the set dscp command.
However, the set dscp command cannot be used with the set precedence command to mark the same packet. The two values, DSCP and precedence, are mutually exclusive. A packet can have one value or the other, but not both.
HTH, please do rate all helpful replies,
Moahmmed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Moahmmed Mahmoud.
set ip dscp = IPv4
set dscp = IPv4 + v6
As stated before, the other answer is top notch as seen many try to do scrating their head on what broke.
