Set priority between two tunnels
boiadzhiew
I have one 2821 router with this part of config;
redundancy
interface Tunnel100
  ip address 192.168.aa.bb 255.255.255.252
 ip mtu 1400
 ip authentication mode eigrp 2 md5
 ip authentication key-chain eigrp 2 EIGRP
 ip tcp adjust-mss 1350
 delay 5000
 tunnel source Vlan48
 tunnel mode ipsec ipv4
 tunnel destination 10.xx.xx.xx
 tunnel vrf sp1
 tunnel protection ipsec profile SP1_CRYPTO
interface Tunnel200
 description === to TP Var SDWAN via Vivacom ===
 ip address 192.168.cc.dd 255.255.255.252
 ip mtu 1400
 delay 10000
 tunnel source FastEthernet0/1/0
 tunnel destination 83.xx.xx.xx
 tunnel vrf sp2
 tunnel protection ipsec profile SP2_CRYPTO shared
Seems Tunnell100 is set as primary and Tunnell200 as reserve but i don't know how, I want to set Tunnell200 as primary and Tunnell100 as reserve. How to set higher priority for Tunnell200?
2 Accepted Solutions
 delay 10000
 delay 5000
the answer is this, flapping the delay and check
MHM
M02@rt37
Hello @boiadzhiew
Same answer as @MHM Cisco World
Adjust the delay on Tunnel200 to make it less preferable.
interface Tunnel100
delay 5000 # Adjust the delay value as needed !
interface Tunnel200
delay 10000 # Set a higher delay value than Tunnel100 !
Best regards
 delay 10000
 delay 5000
MHM
M02@rt37
Hello @boiadzhiew
interface Tunnel100
interface Tunnel200
Best regards
