Set Up Linksys by Cisco RVS 4000
nvconstruction
I've been trying to set up a small network with the RVS 4000 but no luck at the moment. Need urgent help.
Set up is:
Server: 192.168.100.1
Server: 192.168.100.2
Internet Connection: 192.168.100.3 with static IP 10.10.10.10
RVS 4000: 192.168.100.4
Desktop: 192.168.100.5 Default Getaway: 192.168.100.4
VPN connection
Everytime that I try to connect from desktop: no internet
Does anybody have a design or something that I can follow and try it?
Thank you
owillins
Level 6
Level 6
Each PC or network device that uses TCP/IP must have a unique address to identify itself in a network. If the IP address is not unique to a network, Windows will generate an IP conflict error message. You can assign a static IP address to a PC. I hope this might be cause of your issue.
Here is the user guide.
ftp://ftp.linksys.com/downloads/NA/userguide/RVS4000_V10_UG_B8731-web.pdf
