Setting Access Policies Dual Internet Connections
richard-pang
Hello Everyone,
I'm trying to set up a S2S VPN between two ASA5505 SP units running ASA Version 8.2(1). I've ordered additional ADSL2 lines to handle this traffic and I'm having troubles with the configuration for the additional PPPoE connection. Here is are extracts from my current config; First the interface vlans
     interface Vlan1
     nameif inside
     security-level 100
     interface Vlan2
     nameif outside
     security-level 0
     pppoe client vpdn group Internet
     ip address pppoe setroute
     interface Vlan3
     nameif VPN
     security-level 0
     pppoe client vpdn group VPN
     ip address pppoe
Here is the login section;
     vpdn group Internet request dialout pppoe
     vpdn group Internet localname myusername1@myisp.com
     vpdn group Internet ppp authentication chap
     vpdn group VPN request dialout pppoe
     vpdn group VPN localname myusername2@myisp.com
     vpdn group VPN ppp authentication chap
     vpdn username myusername1@myisp.com password *********
     vpdn username myusername2@myisp.com password *********
This all works and I can see both interfaces with PPPoE connectivity, however none of my policies seem to be working on the VPN interface. For instance; I've added the following for ICMP.
     access-list OUTSIDE_IN_ACL extended permit icmp any any echo-reply
     access-list OUTSIDE_IN_ACL extended permit icmp any any time-exceeded
     access-list VPN_access_in extended permit icmp any any echo-reply
     access-list VPN_access_in extended permit icmp any any time-exceeded
     access-group OUTSIDE_IN_ACL in interface outside
     access-group VPN_access_in in interface VPN
     policy-map global_policy
       class inspection_default
         inspect icmp
The result being that I can ping the OUTSIDE interface, but get no reply from the VPN interface.
I've checked ADSL lines, they are up. The two PPPoE sessions are logged in and active. I can even see the ICMP packets hit the VPN interface, but there is no reply. This is as far as my IOS knowledge gets me. Can anyone help?
thanks,
Richard
Eugene Khabarov
Level 7
Level 7
Seems to me that there is routing problem. PPPoE client install the default route? If so which one of two used?
