Setting up 2911 with Etherswitch Module
asdraper1
Hi all,
I am setting up a new 2911 with a ES2-16p switch module.  My question is, do I have to set up a trunk between Ge 1/0 on the router and Ge 0/17 on the switch if all traffic will be carried over VLAN 1?  I know this is not recommended usage, but is it possible without trunking or do I need to set up another VLAN and trunk the connection?
Thanks.
Julio Carvajal
Not sure what you mean,
If all traffic will go over vlan 1 then there is no need, An access port will do it for you.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
