Setting Up Cisco C3660V2 FIBER UP LINK
okoroji80
Dear All ,
i would like to know the config. steps required for setting up fiber link between two cisco c3650v2
If i do : sh run , i hadly see the fiber ports on the switch.
Jude.
resleymj01
Please elaborate on what you mean by "i hadly see the fiber ports."
If what you are asking is a matter of trunking (802.1q) the two switches together, you merely need to configure the interfaces as trunks on both switches with the appropriate VLAN's. You will also need the SFP's for each switch and an LC-LC, duplex fiber. The mode of the fiber must match the SPF i.e. GLC-SX-MM is for multi-mode fiber.
Example config:
Switch-A# config t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch-A(config)# int g0/1
Switch-A(config-if)# switchport trunk encapsulation dot1q
Switch-A(config-if)# switchport trunk allowed vlan 10
Switch-A(config-if)# switchport mode trunk
Switch-A(config-if)# no shut
Switch-A(config-if)# ^z
Switch-A# wr me
Switch-A# exit
Switch-B# config t
Switch-B(config)# int g0/1
Switch-B(config-if)# switchport trunk encapsulation dot1q
Switch-B(config-if)# switchport trunk allowed vlan 10
Switch-B(config-if)# switchport mode trunk
Switch-B(config-if)# no shut
Switch-B(config-if)# ^z
Switch-B# wr me
Switch-B# exit
Provided that the hardware is in place (SFP's on both switches) and cabling, the above configuration should provide what you are looking for.
-Micah
Thanks Micah , thanks for the clarification.
what i mean by ' i hardly see the fiber port '' is this : on typing show run  i do not the fiber ports displying .
the hardwares are all in place am suspecting the fiber cabling from the fiber patch panel.
Jude
Can you post the output to the following commands:
1.  sh interface status
2.  sh idprom interface
Jude,
The commands posted by leolaohoo are good places to look. An example of the sh interface status output is as follows:
3560G-01#show interfaces gigabitEthernet 0/28 status
Port      Name               Status        Vlan       Duplex  Speed Type
Gi0/28                          connected  trunk       a-full     a-1000 10/100/1000BaseTX SFP
An example of the sh idprom interface output is as follows:
cvc-3560g-ott1#sh idprom interface gigabitEthernet 0/28
General SFP Information
Identifier            :   0x03
Connector             :   0x00
Transceiver           :   0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
Encoding              :   0x01
BR_Nominal            :   0x0D
Vendor Name           :   CISCO-AVAGO
Vendor Part Number    :   ABCU-5710RZ-CS2
Vendor Revision       :   0x20 0x20 0x20 0x20
Vendor Serial Number  :   AGM120825NE
Other Information
And so on...
If your SFP is bad you will see the following output:
3560g-01#sh idprom interface gigabitEthernet 0/26
%No module is present
If you see nothing at all when you run any of those commands either the interface does not exist or the software might have a bug in my opinion.
Hope this helps.
-Micah
