Setting UP Cisco C931-4P ISR w/ISP Cable Modem
Chris-PNW
I am new to networking and learning most everything through some classes, books, Internet forums and trial & error on my part (I figure a hands on approach is the best method).  My current problem is that I am unable to get my ISR-931 to route traffic correctly outside of my LAN.  The ISR-931 had two WAN ports and 4 LAN ports.
Background: Currently upgrading all of my home networking equipment from consumer grade Netgear products (FVS318G router/ GS108/GS110TP switches) to commercial products made by Cisco.
New Setup:
- Cisco ISR-931 connected to ISP cable modem (Arris SB8200) on interface Gi4
- Cisco SG250-26HP on interface Ge1 connected to ISR-931 on interface Gi0
- All other peripherials connected to various ports on SG250-26HP
- Will eventually connect the SG250-26HP on interface Ge26 to a VLAN running on another Netgear GS110TP
What I can do:
- Obtain DHCP address on Gi4 from ISP
- ping 200.200.200.200 (loopback0)
- ping 192.168.100.1 (Cable Modem)
- ping 192.168.0.1 (vlan1)
- ping 192.168.0.2 (Cisco SG250-26HP)
- ping 192.168.0.100 (Desktop connected to switch interface Ge7) - This IP address was assigned via DHCP
- ping the ISP address of my cable modem
- ping the default gateway provided by my ISP
What I can't do:
- Access any address outside of the addresses listed above.  There is no Internet access at this point.
I've included as much output from the router to provide everything that I have configured which will hopefully lead to a possible solution.  My guess is that there is something with ACLs that I'm missing or doing incorrectly.  Do I need to configure a VLAN to point to one of the switch interfaces for things to route properly?
Thanks for any help that can be provided.
Here is my current running configuration:
Building configuration...
Current configuration : 3677 bytes
! Last configuration change at 15:31:23 GMT Sun Sep 1 2019 by chris-pnw
version 15.8
service password-encryption
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 xxx
no aaa new-model
clock timezone GMT -8 0
ip dhcp excluded-address 192.168.0.0 192.168.0.99
ip dhcp pool 192.168.0
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 208.76.152.9 208.76.152.1
no ip domain lookup
ip domain name home.com
ip name-server 208.76.152.9
ip name-server 208.76.152.1
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-551513602
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-551513602
revocation-check none
rsakeypair TP-self-signed-551513602
crypto pki certificate chain TP-self-signed-551513602
certificate self-signed 01
xxx
quit
license udi pid C931-4P sn PSZ23021AEY
username chris-pnw privilege 15 secret 9 xxx
redundancy
interface Loopback0
ip address 200.200.200.200 255.255.255.0
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
description PrimaryWANDesc_
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet5
no ip address
duplex auto
speed auto
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 100 interface GigabitEthernet4 overload
ip nat inside source list nat-list interface GigabitEthernet4 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
password 7 xxx
login
line vty 0 4
password 7 xxx
login
transport input ssh
line vty 5 15
password 7 xxx
login
transport input none
scheduler allocate 20000 1000
end
SHOW INTERFACES
GigabitEthernet0 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 70ea.1a29.1050 (bia 70ea.1a29.1050)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Last input 00:00:21, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3000 bits/sec, 2 packets/sec
23484 packets input, 4369244 bytes, 0 no buffer
Received 409 broadcasts (8338 multicasts)
0 watchdog, 0 multicast, 0 pause input
26746 packets output, 9824384 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
414 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1 is down, line protocol is down
Hardware is Gigabit Ethernet, address is 70ea.1a29.1051 (bia 70ea.1a29.1051)
Auto-duplex, Auto-speed
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
GigabitEthernet2 is down, line protocol is down
Hardware is Gigabit Ethernet, address is 70ea.1a29.1052 (bia 70ea.1a29.1052)
GigabitEthernet3 is down, line protocol is down
Hardware is Gigabit Ethernet, address is 70ea.1a29.1053 (bia 70ea.1a29.1053)
GigabitEthernet4 is up, line protocol is up
Hardware is iGbE, address is 70ea.1a29.1054 (bia 70ea.1a29.1054)
Description: PrimaryWANDesc_
Internet address is 25.114.80.234/19
Full Duplex, 1Gbps, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/125/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 109000 bits/sec, 221 packets/sec
1610315 packets input, 96632759 bytes, 0 no buffer
Received 1610135 broadcasts (0 IP multicasts)
0 watchdog, 148 multicast, 0 pause input
3809 packets output, 285025 bytes, 0 underruns
143 unknown protocol drops
2 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet5 is down, line protocol is down
Hardware is iGbE, address is 70ea.1a29.1055 (bia 70ea.1a29.1055)
Auto Duplex, Auto Speed, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Received 0 broadcasts (0 IP multicasts)
1 lost carrier, 0 no carrier, 0 pause output
Loopback0 is up, line protocol is up
Hardware is Loopback
Internet address is 200.200.200.200/24
MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
Encapsulation LOOPBACK, loopback not set
Last input 00:13:26, output never, output hang never
Output queue: 0/0 (size/max)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
NVI0 is up, line protocol is up
Hardware is NVI
Interface is unnumbered. Using address of Loopback0 (200.200.200.200)
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 70ea.1a29.1050 (bia 70ea.1a29.1050)
Internet address is 192.168.0.1/24
Keepalive not supported
Last input 00:00:00, output never, output hang never
5 minute input rate 3000 bits/sec, 3 packets/sec
17155 packets input, 2950780 bytes, 0 no buffer
Received 363 broadcasts (30 IP multicasts)
12185 packets output, 8695033 bytes, 0 underruns
0 output errors, 1 interface resets
1100 unknown protocol drops
SHOW IP INTERFACE BRIEF
GigabitEthernet0 unassigned YES unset up up
GigabitEthernet1 unassigned YES unset down down
GigabitEthernet2 unassigned YES unset down down
GigabitEthernet3 unassigned YES unset down down
GigabitEthernet4 25.114.80.234 YES DHCP up up
GigabitEthernet5 unassigned YES NVRAM down down
Loopback0 200.200.200.200 YES NVRAM up up
NVI0 200.200.200.200 YES unset up up
Vlan1 192.168.0.1 YES NVRAM up up
SHOW IP INTERFACE
Internet protocol processing disabled
Broadcast address is 255.255.255.255
Address determined by DHCP
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is enabled, interface in domain outside
BGP Policy Mapping is disabled
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
Output features: Post-routing NAT Outside, Common Flow Table, Stateful Inspection, NAT ALG proxy
IPv4 WCCP Redirect outbound is disabled
IPv4 WCCP Redirect inbound is disabled
IPv4 WCCP Redirect exclude is disabled
Address determined by non-volatile memory
MTU is 1514 bytes
IP Null turbo vector
Network address translation is disabled
Input features: MCI Check
MTU is 1514 bytes
IP fast switching is disabled
IP CEF switching is disabled
Output features: Post-routing NAT NVI Output
MTU is 1500 bytes
Network address translation is enabled, interface in domain inside
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
Output features: NAT Inside, Common Flow Table, Stateful Inspection, NAT ALG proxy
SHOW IP ROUTE
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, GigabitEthernet4
24.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 25.114.64.0/19 is directly connected, GigabitEthernet4
L 25.114.80.234/32 is directly connected, GigabitEthernet4
172.17.0.0/32 is subnetted, 1 subnets
S 172.17.17.2 [254/0] via 24.113.64.1, GigabitEthernet4
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, Vlan1
L 192.168.0.1/32 is directly connected, Vlan1
200.200.200.0/24 is variably subnetted, 2 subnets, 2 masks
C 200.200.200.0/24 is directly connected, Loopback0
L 200.200.200.200/32 is directly connected, Loopback0
remove the line:
from your configuration. Also, add the keyword 'dhcp' to your static route:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 dhcp
Also, change the access list you use for the NAT translations to a standard access list:
ip nat inside source list 1 interface GigabitEthernet4 overload
access-list 1 permit 192.168.0.0
remove the line:
Georg,
Thank you for your help.  The changes you made to my configuration solved my access routing issue.
Chris
