Setting Up NAT Port Forwarding on 881
jonathanw84
I'm having an issue with a home office employee who we set up with a Cisco 881. Before we installed their 881, she had Foscam cameras at her house connecting to her ISP provided wireless router. The cameras connect wirelessly and she set up port forwarding on the wireless router to access them while outside of her network.
Her new setup is like this:
CISCO 881 > LINKSYS E2500 > Foscam Cameras
She has port forwarding set up on the Linksys E2500 and can access the cameras while on her wireless network. However, when tries to connect to her public IP using the assigned port numbers, it fails.
I have added the following NAT statements to the Cisco router:
ip nat inside source static tcp 172.X.X.X 3417 interface Dialer 10 3417
ip nat inside source static tcp 172.X.X.X 3418 interface Dialer 10 3418
I figured since the cameras are connected to the wireless network, I would need to create the statement to port forward to the wireless router (the 172.X.X.X address). However, this is not working. What am I missing to make this work?
Thanks!
15 Replies 15
John Blakley
What is the "wan" side address for the Linksys? That's the address that you should be forwarding to...
Which device is natting: Cisco or Linksys?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John,
The "wan" address for the Lynkssy is the 172.X.X.X address specified in the nat translation rule listed above.
Both devices are technically natting:
ISP Provided Address > Cisco Router (private network is 172.X.X.X) > Linksys Router (172.X.X.X WAN address, 192.X.X.X LAN address for camera).
Thanks!
Can you ping the internal cameras from the Cisco? Here's what I would do. Disable nat, if possible, on the Linksys. Put a static route in the Cisco pointing the 192.x.x.x subnet to the Linksys wan interface. After you do this, you should be able to change your router to nat the 192.x.x.x address instead of the 172.x.x.x address and having to manage two different devices.
HTH,
John
I cannot. I added a static route on the 881:
ip route 192.168.1.0 255.255.255.0 172.20.16.1
No reponse when I attempt to ping from the router.
So, your Linksys wan address is 172.20.16.1 and the Linksys lan is 192.168.1.0/24. Are you saying that you cannot disable nat on the linksys?
HTH,
John
The Linksys router is not my company's so I do not have access to it's set up. When you say disable nat, are you referring to turning off DHCP on the Linksys and passing that function onto the 881?
No, dhcp can stay on the Linksys, but you need to disable nat on it. So, let's go back to the original problem. From what I understand you have a public address on the Cisco router wan interface, and a 172.20.x.x address on the lan side, and it's configured for nat. The Linksys has a 172.20.x.x address on the wan side, and 192.168.x.x address on the lan side. The cameras are on the 192.168.x.x subnet. They were originally, and probably still are, natted to a 172.20.x.x address before you put the Cisco router in, or were they natted to a public address that the Linksys had? Technically, when the request comes into the Dialer interface to connect to the camera, you're going to forward that request to the Linksys wan interface (unless you have other addresses associated to the camera). The Linksys should see the traffic on the wan side coming in on 3417 and 3418. The camera will get the traffic after the Linksys forwards it to the camera. The camera's default gateway should be configured for the Linksys router and has no idea of it's wan address.
Can you post the rest of the Cisco config? The dialer interface, lan/vlan interface, and the acls for the nat configuration?
The easiest thing to do is disable nat on the Linksys. Can you have the person that owns it get you into it?
Your assesment is correct. Previously, they were natted to a public address that the Linksys had. Now it is natting to a 172.20.X.X address which in turn is natted to the public IP. I can work with them to turn off natting.
Here is the pertinent information in the config:
interface Tunnel0
ip address X.X.X.X 255.255.255.0
ip access-group 110 out
no ip redirects
ip mtu 1400
ip flow ingress
ip flow egress
ip nhrp authentication DMVPN_NW
ip nhrp map multicast X.X.X.X
ip nhrp map X.X.X.X X.X.X.X
ip nhrp network-id 211
ip nhrp holdtime 360
ip nhrp nhs X.X.X.X
ip nhrp registration no-unique
ip tcp adjust-mss 1360
delay 1000
tunnel source Dialer10
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile SDM_Profile1 shared
interface Tunnel1
no ip redirects
ip mtu 1400
ip nhrp network-id 212
ip nhrp nhs X.X.X.X
delay 2000
tunnel key 200000
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
description DMZ for Home Internet Access
switchport access vlan 172
no ip address
interface FastEthernet4
description External Internet Connection
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
interface Vlan1
ip access-group 121 in
ip nat inside
ip virtual-reassembly in
interface Vlan172
ip address 172.20.16.254 255.255.255.0
ip nat inside
interface Dialer10
bandwidth 100000
ip address negotiated
ip access-group 120 in
ip mtu 1492
ip flow ingress
ip flow egress
ip nat outside
ip inspect FIREWALL out
encapsulation ppp
dialer pool 10
dialer-group 10
ppp authentication pap chap callin
ppp chap hostname XXXX
ppp chap password 0 XXXX
ppp pap sent-username XXXX
no cdp enable
hold-queue 224 in
exit
ip nat inside source list 20 interface Dialer10 overload
ip nat inside source list 30 interface Dialer10 overload
ip nat inside source static tcp 172.20.16.1 3417 interface Dialer10 3417
ip nat inside source static tcp 172.20.16.1 3418 interface Dialer10 3418
Are you allowing 3417 and 3418 through your 120 acl?
HTH,
John
Yes I am. I even tried it with the acl removed. No such luck.
Hmm..what about telnetting to that port from the Cisco router. Try from the cisco "telnet 172.20.16.1 3417". If it times out, there's something going on with the Linksys. If it states that it's open, then try removing the acl and the cbac configuration (ip inspect) from the interface of the dialer.
HTH,
John
Hi John,
No go on the telnetting. I had my colleague connect her camera directly to a port on the 172 network, I changed the ip nat statements to reflect the new 172 address and we were still unsuccessful. Could it be something on the cbac configuration on the dialer interface that is preventing this from working?
From where is she doing this? if this is from the inside then it is normal behaviour as Cisco routers don't do nat hairpinning with regular NAT but they do with NVI NAT( ip nat enable command under interface instead of ip nat inside and ip nat outside AND ip nat source instead of ip nat inside source).
Alain
For troubleshooting, you could remove the acl and the cbac config. If the camera was working properly, you should have been able to leave the camera on the 192.x.x.x subnet and telnet to the 172.x.x.x address that's on the Linksys interface on that port and get a response. I doubt your cbac config is blocking that because it would be going out of your other interface. By chance, have you rebooted the Linksys after making your address changes from public to private? I'm wondering if the Linksys is somehow thinking that the camera's address is still tied to a public address on the Linksys even though you changed it to a private.
HTH,
John
