Setting up Public Internet Segment - Issues with VLAN
Boon Keat Gan
I am creating a public segment for Guest wireless and Video Conferencing equipment would allow external client using it.
As you can see from the diagram below, the connection from Cisco Router 881 to internet and PIX 515E to Cisco 881 are working fine. I can surf internet by direct plug in to the Router or PIX.
The issues encountered are that I was unable to surf to internet by plug in the Computer to Cisco Switch 2960.
The Cisco Switch 2960 are set to VLAN 90 and assigned to the remaining 24 ports. As we need to plug in Wireless AP to this switch the VLAN setting is a must.
If I change the port to trunk, it was able to surf the internet.  So, it must be something to do with the VLAN and routing.
Appreciate if anyone can advise or tell me what is wrong with the setup. Thank you.
Config for CIsco 881:-
interface FastEthernet0
description Public LAN Segment
switchport access vlan 95
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 203.125.1.2 255.255.255.252
duplex full
speed 100
traffic-shape rate 20480000 1280000 1280000 1000
interface Vlan1
no ip address
interface Vlan95
ip address 203.125.2.2 255.255.255.240
ip route 0.0.0.0 0.0.0.0 203.125.1.1
access-list 101 permit ip any any
Config for PIX 515E:-
interface Ethernet0
nameif Internet
security-level 0
ip address 203.125.2.1 255.255.255.240
interface Ethernet1
nameif Internal
security-level 90
ip address 192.168.1.254 255.255.255.0
access-list 101 extended permit ip any any
global (Internet) 1 interface
nat (Internal) 1 192.168.1.0 255.255.255.0
access-group 101 in interface Internal
route Internet 0.0.0.0 0.0.0.0 203.125.28.174 1
Cisco 2960 Config:-
interface FastEthernet0/1
switchport access vlan 90
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
switchport mode trunk
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan90
ip address 192.168.1.253 255.255.255.0
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.254
Latchum Naidu
Hi Boon,
See the below thred will help you.
https://supportforums.cisco.com/message/3267751#3267751
Please rate the helpfull posts.
Naidu.
Thanks for the useful information.
I have resolve my problem.
It is due to vlan.dat file. Delete it away and everything resolve. Thanks!
