SETUP message at reload
At reload of some router platform/IOS rls I noticed following messages...(router does not have startup-config)
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(21a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 29-Sep-08 18:55 by prod_rel_team
BIST FAILED...
Unknown file system detected.
Use format command to format the card as DOS File System.
Or use erase command to format the card as Low End File System.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3725 (R7000) processor (revision 0.1) with 118784K/12288K bytes of memory.
Processor board ID XXXXXXXXXXX
R7000 CPU at 240MHz, Implementation 39, Rev 2.1, 256KB L2, 512KB L3 Cache
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity enabled.
55K bytes of NVRAM.
16384K bytes of ATA System CompactFlash (Read/Write)
SETUP: new interface FastEthernet0/0 placed in "shutdown" state  <----------------------------- ??
SETUP: new interface Serial0/0 placed in "shutdown" state  <--------------------------------------- ??
SETUP: new interface FastEthernet0/1 placed in "shutdown" state
SETUP: new interface Serial0/1 placed in "shutdown" state
Someone can help me in understanding the meaning ?
Thanks in advance
paolo bevilacqua
These are normal messages for a router booting without configuration.
Thanks for the answer....
So I can guess when a router boot w/o startup-config SETUP applies a "default configuration" in which, for instance, the interfaces are administratively shutted down (as implicated by message SETUP: new interface placed in "shutdown" state these interfaces are "new" from IOS point of view)
Does it make sense ?
thanks
Yes. This kind of topics is also covered in documentation, standard training, etc.
