Several questions about control plane protection on Cisco 870 and 1800 series routers
Alen Danielyan
Hi!
I have several questions about CP policing and protection. I read:
Cisco IOS Security Configuration Guide: Securing the Control Plane 12.4T
Infrastructure Protection on Cisco IOS Software-Based Platforms
Control Plane Policing chapter in Cisco IOS Quality of Service Solutions Configuration Guide 12.4T and some other docs.
Still have questions.
We have DMVPN (GRE over IPSec, AES 256bit encryption) network with Cisco 1811 (IOS 12.4T) as hubs and Cisco 871 (IOS 12.4T) as spokes.
Let's start with the spokes. Spokes are doing only VPN connection to the HQ, nothing more.
Q 1.
1) We have ALCs on external interfaces allowing only: ESP, ISAKMP, SSH and ICMP from the hub (sic!).
2) Because of poor CPU in encryption to protect CPU from overload (some of the lines have quite high speeds) I decided to restrict traffic volume to router and changed all the interfaces speeds to 10mbps FD.
3) Besides, I am going to use shaping and polcing to further restrict traffic volume to\from the external interfaces down to 5mbps. (My tests showed that the router can handle only 4.5-5mbps full duplex encrypted traffic with our configs while CPU load is still 80% or lower. On 6-7mbps it reaches 100% load)
Taking into account the above mentioned, do I still need CoPP as DoS protection?
I mean I believe this router is able to process 10mbps (unencrypted) traffic flowing simultaneously through its LAN and 3 WAN interfaces, why should I use CoPP? Proccessing would be in fact to process hub traffic and drop all foreign traffic according to the ACLs (of course I am not protected from LAN side, but 10mbps interface speed would be good protection, IMHO).
I wrote the following config for CoPP (for CP transit and CEF exceptions I just did not know which limits to set and just set quite high limits, need your advice on the limits values):
ip access-list extended cp_esp
permit esp any any
deny   ip any any
ip access-list extended cp_icmp
permit icmp any any
deny   ip any any
ip access-list extended cp_isakmp
permit udp any eq isakmp any eq isakmp
deny   ip any any
ip access-list extended cp_ssh
permit tcp any any eq 22
deny   ip any any
class-map match-all cp_ssh
match access-group name cp_ssh
class-map match-all cp_esp
match access-group name cp_esp
class-map match-all cp_isakmp
match access-group name cp_isakmp
class-map match-all cp_icmp
match access-group name cp_icmp
policy-map CP_Policy_Host
class cp_icmp
    police 50000 conform-action transmit  exceed-action drop
class cp_isakmp
class cp_esp
    police 5000000 conform-action transmit  exceed-action drop
class cp_ssh
    police 20000 conform-action transmit  exceed-action drop
class class-default
    police 10000 conform-action transmit  exceed-action drop
policy-map CP_Policy_Transit
class class-default
    police 10000000 conform-action transmit  exceed-action drop
policy-map CP_Policy_CEF-Exc
class class-default
    police 1000000 conform-action transmit  exceed-action drop
Q 2. I used 5mbps limit for ESP and much lower for other types of traffic on CP host, 10mbps common limit on transit and 1mbps common limit on CEF exceptions subinterface.
Please advice the values taking into account the routers model is Cisco 871? (ignore our traffic real valumes, tell me the limits this router can still handle without 100% CPU load, please)
Q 3. I see only ISAKMP traffic is being matched, ESP is not in class-map cp_esp!?
The same time I can see ESP is matched by the ACL applied to the respective external interfaces. Why? ESP is not reaching CP? But this routers are doing software based encryption\decryption!
I don't understand this. Please clarify.
Q 4. Only quite a low volume of traffic is matched by CEF exceptions policy and almost none by Transit policy!? Why?
And to which limits I can safely decrease the values?
Thank you in advance.
Alen Danielyan
Cann't anyone advise anything?
Please.
Alen Danielyan
Why anyone does not share with his opinion?
