SFP in ASR1001 for Gigabit Ethernet connections?
david.ling
I currently have SMF/MMF SFPs in an ASR 1001 router. I want to replace these fiber conection with an GigE connection. Must I order a GE-T SFP connector or can I just take out the Fiber SFP and use the port?
balaji.bandi
depends on the module - Small Form-Factor Pluggable (SFP) with Fibre SFP,  you want to use Copper then you need to get GLC-T Copper SFP.
Again make sure the distrance of Copper support.
BB
Joseph W. Doherty
If you only have SFP ports you'll need copper SFPs.
Some platforms have copper and SFP ports that logically share a port.  For those, you often need to configure the port whether to use the copper or SFP physical port.
