SG250 routing L3
plavielle
Hi.
I have setup a fonctionning L3 SG250-08. Why L3 mode, because it works 1000 times more than in L2 mode (just test transfert file)
My question was simple : as soons as i have configured some port in "switchport mode layer 3" all other port on the switch are unusable in classic vlan configuration ????
In other word, i have configured 4 port in Layer 3, and i want to use other ports as classic VLAN port. Can i do this ???
Thanks for your responses
plavielle
This case can be close. I think i have made some mistake, but L3 routing is working well.
Thanks.
Joseph W. Doherty
It shouldn't be faster.
Because you need to associate a VLAN with L3.  On the same device, this would be done using a switch virtual interface (SVI).  (As I'm unfamiliar with SG devices, cannot say how this can be done.)
On a SG250, if a "L2" switch, a L3 address might be just a management address, and if so, you would associate that with a particular VLAN.
Possibly.  Again, if your L3 ports are routable, than you would need to define a SVI for your "classic" VLAN ports.
Cannot say for sure for a SG250, but if it has CLI support, the two kinds of ports might look somewhat like:
interface FastEthernet0/1 !a routed port, not VLAN association
 no switchport
 ip address 192.168.2.1 255.255.255.0
interface Vlan1 !for all the VLAN 1 ports
I do not have personal experience with this model of switch. But I am wondering about the command mentioned in the original post >pre>switchport mode layer 3. Like Joseph I am familiar with the
no switchport
command which is used in interface config mode and makes that particular port a layer 3 port and no longer a layer 2 switch port. I wonder if the command mentioned in the original post was entered in global config mode and affected ALL switch ports?
Rick
plavielle
Thanks.
Thanks for the update. Good to know that L3 routing is working.
Rick
