10-19-2020 05:55 AM
hello,
I m new here and trying to enable interVlan on sg550x. however, it failed to register ip routing in running configuration.
could you guys show me how?
below is before and after update conf
switche5cb3f#sh run | include ip voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone ip dhcp server ip dhcp pool network storage ip ssh server ip address 10.1.2.5 255.255.255.0 no ip address dhcp ip address 192.168.2.1 255.255.255.0 ip default-gateway 10.1.2.3 switche5cb3f# switche5cb3f# switche5cb3f# switche5cb3f#conf switche5cb3f(config)#ip routing switche5cb3f(config)#end switche5cb3f#sh run | include ip voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone ip dhcp server ip dhcp pool network storage ip ssh server ip address 10.1.2.5 255.255.255.0 no ip address dhcp ip address 192.168.2.1 255.255.255.0 ip default-gateway 10.1.2.3 switche5cb3f#
and full configuration
switche5cb3f#sh run config-file-header switche5cb3f v2.5.5.47 / RTESLA2.5.5_930_364_286 CLI v1.0 file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0 ! ! unit-type-control-start unit-type unit 1 network gi uplink te unit-type unit 2 network gi uplink te unit-type unit 3 network gi uplink te unit-type unit 4 network gi uplink te unit-type unit 5 network gi uplink te unit-type unit 6 network gi uplink te unit-type unit 7 network gi uplink te unit-type unit 8 network gi uplink te unit-type-control-end ! vlan database vlan 30,40,50,60 exit voice vlan oui-table add 0001e3 Siemens_AG_phone voice vlan oui-table add 00036b Cisco_phone voice vlan oui-table add 00096e Avaya voice vlan oui-table add 000fe2 H3C_Aolynk voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone voice vlan oui-table add 00e075 Polycom/Veritel_phone voice vlan oui-table add 00e0bb 3Com_phone ip dhcp server ip dhcp pool network storage address low 192.168.2.50 high 192.168.2.100 255.255.255.0 dns-server 9.9.9.9 exit bonjour interface range vlan 1 hostname switche5cb3f username admin password encrypted xxxxx privilege 15 ip ssh server clock timezone J +8 ! interface vlan 1 ip address 10.1.2.5 255.255.255.0 no ip address dhcp ! interface vlan 30 name storage ip address 192.168.2.1 255.255.255.0 ! interface vlan 40 name WiFi_tv ! interface vlan 50 name WiFi_bed ! interface vlan 60 name vm ! interface GigabitEthernet1/0/1 switchport mode trunk switchport general allowed vlan add 1 untagged switchport trunk allowed vlan 1 ! interface GigabitEthernet1/0/12 switchport mode trunk switchport general allowed vlan add 1,40,50,60 tagged switchport general allowed vlan add 30 untagged switchport access vlan 30 switchport general pvid 30 switchport trunk native vlan 30 switchport trunk allowed vlan 1,30,40,50,60 ! interface GigabitEthernet1/0/13 switchport mode trunk switchport general allowed vlan add 1,40,50,60 tagged switchport general allowed vlan add 30 untagged switchport access vlan 30 switchport general pvid 30 switchport trunk native vlan 30 switchport trunk allowed vlan 1,30,40,50,60 ! interface GigabitEthernet1/0/36 switchport mode trunk switchport general allowed vlan add 1,40,50,60 tagged switchport general allowed vlan add 30 untagged switchport access vlan 30 switchport general pvid 30 switchport trunk native vlan 30 switchport trunk allowed vlan 1,30,40,50,60 ! interface GigabitEthernet1/0/47 switchport mode trunk switchport general allowed vlan add 1,40,50,60 tagged switchport general allowed vlan add 30 untagged switchport access vlan 30 switchport general pvid 30 switchport trunk native vlan 30 switchport trunk allowed vlan 1,30,40,50,60 ! interface GigabitEthernet1/0/48 switchport mode trunk switchport trunk allowed vlan 1,30,40,50,60 ! exit ip default-gateway 10.1.2.3
10-19-2020 07:06 AM
Not hands on this SMB switch.
try below option if this is option on your GUI
10-19-2020 08:23 AM
You have 2 vlans with IP addresses configured. Perhaps you could do some testing to see what works. I would suggest these steps.
- Connect a device to a port in vlan 30.
- You have a DHCP pool configured for vlan 30. Check whether the device received a correct IP address, mask, and gateway.
- If the device did receive correct parameters test whether the device can access its gateway (ping the address of vlan 30 192.168.2.1).
- If the device did successfully ping the vlan 30 interface then test whether the device is able to ping the vlan 1 interface address 10.1.2.5.
If the device is able to ping both interface addresses then it demonstrates that there is inter vlan routing. If the ping fails then it indicates that we need to do more investigating about why it is not working.
10-19-2020 08:52 AM - edited 10-19-2020 08:55 AM
hello Richard,
it is kinda weird on my device. Thanks helping.
vlan 1
admin@MacBook-Air ~ % ip addr sh lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 inet 127.0.0.1/8 lo0 inet6 ::1/128 inet6 fe80::1/64 scopeid 0x1 inet 127.94.0.1/8 lo0 inet 127.94.0.2/8 lo0 en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 38 inet6 fe80::18/64 secured scopeid 0x4 inet 10.1.2.12/24 brd 10.1.2.255 en3 admin@MacBook-Air ~ % ping 10.1.2.5 PING 10.1.2.5 (10.1.2.5): 56 data bytes 64 bytes from 10.1.2.5: icmp_seq=0 ttl=64 time=2.242 ms 64 bytes from 10.1.2.5: icmp_seq=1 ttl=64 time=1.165 ms 64 bytes from 10.1.2.5: icmp_seq=2 ttl=64 time=1.125 ms 64 bytes from 10.1.2.5: icmp_seq=3 ttl=64 time=1.095 ms ^C --- 10.1.2.5 ping statistics --- 4 packets transmitted, 4 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 1.095/1.407/2.242/0.483 ms admin@MacBook-Air ~ % ping 10.1.2.3 PING 10.1.2.3 (10.1.2.3): 56 data bytes 64 bytes from 10.1.2.3: icmp_seq=0 ttl=64 time=0.368 ms 64 bytes from 10.1.2.3: icmp_seq=1 ttl=64 time=0.434 ms 64 bytes from 10.1.2.3: icmp_seq=2 ttl=64 time=0.469 ms 64 bytes from 10.1.2.3: icmp_seq=3 ttl=64 time=0.492 ms 64 bytes from 10.1.2.3: icmp_seq=4 ttl=64 time=0.454 ms 64 bytes from 10.1.2.3: icmp_seq=5 ttl=64 time=0.418 ms ^C --- 10.1.2.3 ping statistics --- 6 packets transmitted, 6 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 0.368/0.439/0.492/0.040 ms admin@MacBook-Air ~ % ping 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes Request timeout for icmp_seq 0 Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 ^C --- 192.168.2.1 ping statistics --- 4 packets transmitted, 0 packets received, 100.0% packet loss admin@MacBook-Air ~ %
vlan 30
admin@MacBook-Air ~ % ip addr sh lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 inet 127.0.0.1/8 lo0 inet6 ::1/128 inet6 fe80::1/64 scopeid 0x1 inet 127.94.0.1/8 lo0 inet 127.94.0.2/8 lo0 en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 38: inet6 fe80::/64 secured scopeid 0x4 inet 192.168.2.50/24 brd 192.168.2.255 en3 admin@MacBook-Air ~ % ping 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes 64 bytes from 192.168.2.1: icmp_seq=0 ttl=64 time=0.954 ms 64 bytes from 192.168.2.1: icmp_seq=1 ttl=64 time=1.214 ms 64 bytes from 192.168.2.1: icmp_seq=2 ttl=64 time=1.166 ms 64 bytes from 192.168.2.1: icmp_seq=3 ttl=64 time=1.257 ms ^C --- 192.168.2.1 ping statistics --- 4 packets transmitted, 4 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 0.954/1.148/1.257/0.116 ms admin@MacBook-Air ~ % ping 10.1.2.5 PING 10.1.2.5 (10.1.2.5): 56 data bytes 64 bytes from 10.1.2.5: icmp_seq=0 ttl=64 time=0.975 ms 64 bytes from 10.1.2.5: icmp_seq=1 ttl=64 time=1.219 ms 64 bytes from 10.1.2.5: icmp_seq=2 ttl=64 time=1.088 ms 64 bytes from 10.1.2.5: icmp_seq=3 ttl=64 time=1.222 ms 64 bytes from 10.1.2.5: icmp_seq=4 ttl=64 time=1.195 ms 64 bytes from 10.1.2.5: icmp_seq=5 ttl=64 time=1.146 ms ^C --- 10.1.2.5 ping statistics --- 6 packets transmitted, 6 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 0.975/1.141/1.222/0.088 ms admin@MacBook-Air ~ % ping 10.1.2.3 PING 10.1.2.3 (10.1.2.3): 56 data bytes Request timeout for icmp_seq 0 Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 Request timeout for icmp_seq 3 Request timeout for icmp_seq 4 ^C --- 10.1.2.3 ping statistics --- 6 packets transmitted, 0 packets received, 100.0% packet loss admin@MacBook-Air ~ % ping 1.1.1.1 PING 1.1.1.1 (1.1.1.1): 56 data bytes Request timeout for icmp_seq 0 Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 ^C --- 1.1.1.1 ping statistics --- 4 packets transmitted, 0 packets received, 100.0% packet loss admin@MacBook-Air ~ %
and inside sg550x
switche5cb3f#ping 10.1.2.3 Pinging 10.1.2.3 with 18 bytes of data: 18 bytes from 10.1.2.3: icmp_seq=1. time=0 ms 18 bytes from 10.1.2.3: icmp_seq=2. time=0 ms 18 bytes from 10.1.2.3: icmp_seq=3. time=10 ms 18 bytes from 10.1.2.3: icmp_seq=4. time=0 ms ----10.1.2.3 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip (ms) min/avg/max = 0/2/10 switche5cb3f#ping 10.1.2.5 Pinging 10.1.2.5 with 18 bytes of data: 18 bytes from 10.1.2.5: icmp_seq=1. time=0 ms 18 bytes from 10.1.2.5: icmp_seq=2. time=0 ms 18 bytes from 10.1.2.5: icmp_seq=3. time=0 ms 18 bytes from 10.1.2.5: icmp_seq=4. time=0 ms ----10.1.2.5 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip (ms) min/avg/max = 0/0/0 switche5cb3f#ping 1.1.1.1 Pinging 1.1.1.1 with 18 bytes of data: PING: no reply from 1.1.1.1 PING: timeout PING: no reply from 1.1.1.1 PING: timeout PING: no reply from 1.1.1.1 PING: timeout PING: no reply from 1.1.1.1 PING: timeout ----1.1.1.1 PING Statistics---- 4 packets transmitted, 0 packets received, 100% packet loss switche5cb3f#ping 192.168.2.1 Pinging 192.168.2.1 with 18 bytes of data: 18 bytes from 192.168.2.1: icmp_seq=1. time=0 ms 18 bytes from 192.168.2.1: icmp_seq=2. time=0 ms 18 bytes from 192.168.2.1: icmp_seq=3. time=0 ms 18 bytes from 192.168.2.1: icmp_seq=4. time=0 ms ----192.168.2.1 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip (ms) min/avg/max = 0/0/0 switche5cb3f#ping 192.168.2.110 Pinging 192.168.2.110 with 18 bytes of data: 18 bytes from 192.168.2.110: icmp_seq=1. time=0 ms 18 bytes from 192.168.2.110: icmp_seq=2. time=0 ms 18 bytes from 192.168.2.110: icmp_seq=3. time=10 ms 18 bytes from 192.168.2.110: icmp_seq=4. time=0 ms ----192.168.2.110 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip (ms) min/avg/max = 0/2/10 switche5cb3f#ping 10.1.2.12 Pinging 10.1.2.12 with 18 bytes of data: 18 bytes from 10.1.2.12: icmp_seq=1. time=0 ms 18 bytes from 10.1.2.12: icmp_seq=2. time=0 ms 18 bytes from 10.1.2.12: icmp_seq=3. time=10 ms 18 bytes from 10.1.2.12: icmp_seq=4. time=0 ms ----10.1.2.12 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip (ms) min/avg/max = 0/2/10
10-19-2020 08:37 AM
this fix doesn't work on me, thanks
10-19-2020 08:18 AM
did you enable ip routing from the command line ?
10-19-2020 08:59 AM
this is exactly my problem. this particular command was not saved to running config
and the worst is it did not prompt any error in return. Thanks.
10-19-2020 09:16 AM
and out-going uplink not works on vlan 30.
one more thing when I directly plug into port of vlan 1.
the router is 10.1.2.3 instead of sg550x 10.1.2.5
ryan@MacBook-Air ~ % ping 1.1.1.1 PING 1.1.1.1 (1.1.1.1): 56 data bytes 64 bytes from 1.1.1.1: icmp_seq=0 ttl=59 time=3.360 ms 64 bytes from 1.1.1.1: icmp_seq=1 ttl=59 time=4.182 ms 64 bytes from 1.1.1.1: icmp_seq=2 ttl=59 time=4.000 ms 64 bytes from 1.1.1.1: icmp_seq=3 ttl=59 time=3.519 ms ^C --- 1.1.1.1 ping statistics --- 4 packets transmitted, 4 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 3.360/3.765/4.182/0.337 ms ryan@MacBook-Air ~ % ip addr sh lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 inet 127.0.0.1/8 lo0 inet6 ::1/128 inet6 fe80::1/64 scopeid 0x1 inet 127.94.0.1/8 lo0 inet 127.94.0.2/8 lo0 en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 38: inet6 fe80::/64 secured scopeid 0x4 inet 10.1.2.12/24 brd 10.1.2.255 en3 ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ip addr sh lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 inet 127.0.0.1/8 lo0 inet6 ::1/128 inet6 fe80::1/64 scopeid 0x1 inet 127.94.0.1/8 lo0 inet 127.94.0.2/8 lo0 en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 38 inet6 fe80::/64 secured scopeid 0x4 inet 192.168.2.50/24 brd 192.168.2.255 en3 ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ryan@MacBook-Air ~ % ping 1.1.1.1 PING 1.1.1.1 (1.1.1.1): 56 data bytes Request timeout for icmp_seq 0 Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 Request timeout for icmp_seq 3 ^C --- 1.1.1.1 ping statistics --- 5 packets transmitted, 0 packets received, 100.0% packet loss ryan@MacBook-Air ~ %
