sh controller output T1 0/0/0 is down.
lerner cisco
can any one help me quickly on the controller query .
cisco 2921 router ,  card type VWIC3-2MFT-T1/E1   Slot 0 SubSlot 0"   following configuration done on the router , however no serial link connected on the Wan interface Se0/0/0:0  . when I give  sh controllers t1 0/0/0 brief  . the out put shows . T1 0/0/0 is down.
would like to know , when enable controller with below configuration , controller T1 0/0/0 i should show up ?? , or  it will be up when serial line  is up & connected to the interface  Se0/0/0:0  . please suggest
card type t1 0 0
controller T1 0/0/0
 fdl both
 clock source internal
 cablelength long 0db
 channel-group 0 timeslots 1-24
 no shut
Mark Malone
Think you need to configure at least the encapsulation and ip address on serial and connect it should come up then
