Sh version
adamgibs7
Level 6
Level 6
  • Do i have to upload a crypto IOS for SSH and Https features to use.
  • Can i upload a security IOS for switches to support all security related features for switching.Can anybody guide me which IOS???
Switch#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE6, RELEASE SOFTWARE (fc1)
Switch uptime is 10 weeks, 2 days, 2 hours, 36 minutes
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
cisco WS-C2960-48TC-L (PowerPC405) processor (revision F0) with 61440K/4088K bytes of memory.
Processor board ID FOC1219Z47E
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:21:A1:88:45:80
Motherboard assembly number     : 73-9835-09
Power supply part number        : 341-0097-02
Motherboard serial number       : FOC12193G67
Power supply serial number      : DCA121882TE
Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C2960-48TC-L
System serial number            : FOC1219Z47E
Top Assembly Part Number        : 800-26672-04
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COM3F00BRC
Hardware Board Revision Number  : 0x02
Switch   Ports  Model              SW Version              SW Image
Switch#sh flash:
Directory of flash:/
    2  -rwx         976   Mar 1 1993 00:00:29 +00:00  vlan.dat
    4  -rwx        2637  Dec 31 1993 18:07:31 +00:00  config.text
    5  -rwx           5  Dec 31 1993 18:07:31 +00:00  private-config.text
    7  drwx         192   Mar 1 1993 00:07:21 +00:00  c2960-lanbase-mz.122-35.SE5
32514048 bytes total (24175616 bytes free)
Taken from http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swiosfs.html#wp1031507
To delete a directory with all its files and subdirectories, use the delete /force /recursive filesystem:/file-url privileged EXEC command.
Regards.
8 Replies 8
k_srinadh
Hi ,
Your  cisco WS-C2960-48TC has 57 MB memory is free
Download IOS from following Site
http://www.cisco.com/cisco/software/type.html?mdfid=280590240&flowid=2552
Hope this Helps
Srinadh
Hello Friends,
My IOS is been copied successfully i want to copy a html folder that contains folders and files that belongs to web browser configuration tools,when i try to copy the whole folder by specifying folder name and tftp server ip address it give me the below error.
Error opening tftp://10.10.10.10/html
Any clues dears
You have to copy one file at a time
Hello Dear
Attached is the folder, I have to copy all the files 1 by 1,??? there is no other way,when i downloaded the IOS it came in tar file when i extract that i recieved this folder and a IOS image, Is it some alternative with .tar file to extract in switch flash.
Dear's
I got the solution i have upgraded the IOS with all of its folders and file related to web based access through archive download-sw command.
I want to delete a Directory form flash, in 2960 swith with 12.2.55 IOS how cani do it???? what is the command.
Thanks.
bootloader rmdir  command is what you need but the directories must be empty.
So first navigate into the file hierarchy with the dir  command then delete files with the delete command.
Regards.
There is no such bootloader rmdir  command in the above mentioned IOS.
Regards.
