Shaping a link
John Blakley
All,
I have a 20mb DS3 that's getting installed at a remote branch. We have a 20mb DS3 circuit here as well, and we don't want the remote branch being able to suck down all of our bandwidth.
I can shape the traffic on the outside interface for the remote branch, but if I shaped it from 20mb to 3mb, would that take a major hit on the routers cpu? It's a DR site, and the only time we want them to be able to use 20mb is if we had to go over there because of a DR situation. The router is a 3745, and there are about 100 users at this location.
John
HTH, John *** Please rate all useful posts ***
5 Replies 5
andrew.prince
Level 10
Level 10
That should not impact the CPU that much to be honest.
HTH>
Jon Marshall
John
Shaping does incur extra CPU overhead but it is really quite minimal and if adding shaping to the router has a major impact on CPU then you probably need a better router anyway.
With what you have you should be fine.
Jon
paolo bevilacqua
Which exact type of circuit is that? If p-t-p DS3 you can use dsu commands to limit bandwidth.
Joseph W. Doherty
As the others have noted, yes you could and CPU is (usually) minimal. (re: usually, I've noticed on the later 12.4T versions, the default Tc now appears to be 4ms and I've seen such a minimal value impact the CPU. [If it does, increasing Tc appears to reduce CPU impact.])
PS:
As an alternative, instead of always limiting the bandwidth to the remote site, you could also consider using something like CBWFQ with a 15% bandwidth setting. This should also provide 3 Mbps but will allow more if not otherwise being used.
