Shaping doesn't work on a gigE interface..options?
davidhuynh5
Please see the attachement. I have a 622Mbps circuit that's connected to a gigE interface on my router.
I only want to use 311Mbps out of the entire 622Mbps pipe. When I try to apply the shaping command, it replys that commad is not supported on this interface. What are my other options to restrict that interface and minimize output drops. Any sample configuration would be greatly appreicated.
Thanks in advance.
Marwan ALshawi
did you try policing or Rate limiting
/CAR?
Marwan ALshawi
/CAR?
