Shaping GigE Interface to OC-12 Pipe
davidhuynh5
We have an OC-12 circuit (622Mbps) connected to our router's gigE interface (inter g1/0). Although the physocal interface is 1000Mbps the actual line speed is 622Mbps. If I get an offer load of 1 gig of data going through the interface, only 622Mb will be processed, while the remaining 378Mb will get queued or dropped. Does anyone have a shaping "configuration" that will shape/buffer the traffic once it it's 622Mbps.
My primary goal is to prevent ouput drop on the gigE interface as much possible. Thanks in advance.
2 Accepted Solutions
Jerry Ye
Please specify what type of router? Shaping config should be similar to the following
policy-map SHAPE
class class-default
  shape average 622000000
interface xxxx
service-policy out SHAPE
HTH,
jerry
Hello David,
be aware that outbound shaping is not supported on all platforms for example on a standard GE port of a C6500/7600 just to make an example.
It is supported on routers and on WAN oriented modules of C6500/7600
Hope to help
Giuseppe
5 Replies 5
Jerry Ye
policy-map SHAPE
class class-default
interface xxxx
HTH,
jerry
Thanks Jerry.
Hello David,
Hope to help
Giuseppe
Thanks Giuseppe. I found that out today when I tried to configure it on an interface and it can back
"not supported on this interface" :-(
Hi David,
That was my first question to you initially "Please specify what type of router?".
jerry
