Shaping
acutx5678
I've been having people downloading mail ost and hogging the bandwidth I setup shaping but doesn't seem to be working, i looked up different posts here and tried both policing and shaping but doesn't seem to be working.
This is over an MPLS network, and it happens acorss the board at different remote locations below is how I set it up but it doesn't seem to be helping, any advise/help is appreciated.
class-map match-any Shaped
description Exchange Server
match access-group 105
policy-map bandwidth-control
class Shaped
    shape average 600000
interface FastEthernet0/0
no ip address
ip helper-address 192.168.0.26
duplex auto
speed auto
interface FastEthernet0/0.10
description Data VLAN 10
encapsulation dot1Q 10
ip address xxx.xx.x.1 255.255.255.0
ip directed-broadcast
service-policy output bandwidth-control
interface Serial0/0/0
ip address
ip flow ingress
encapsulation ppp
service-policy output llq
router bgp 65001
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor
no auto-summary
no ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 105 permit ip any host 192.168.0.38
Hello
Clase based:
ip access-list extended server
class-map match-all server_cm
match access-group name server
policy-map server_pm
class server_pm
police 6144000 192000 conform-action transmit exceed-action drop
int (lan facing)
service-policy input server_pm
CAR
access-list 100 permit ip any host 192.168.0.38
interface (wan)
rate-limit output access-group 100 6144000 115200 2304000 conform-action transmit exceed-action drop
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
10 Replies 10
acutx5678
By the way I set this configuration on the router at the location which is being affected with the bandwidth issue.
Can you see that your ACL 105 is matched?
#show ip access 105
Can you provide detailed configuration, also with IP addresses (if some of them are public, show us at least first two octets)
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
#sh ip access 105
Extended IP access list 105
    10 permit ip any host 192.168.0.38
that's the IP of the exchange server.
Can you please post output of #sh ip cef 192.168.0.38 to verify my theory, if I will be right I will tell you what is it .
Best Regards
192.168.0.0/24
  nexthop x.x.x.x Serial0/0/0
that's the public IP at nexthop.
What is your theory ?
the serial has the service-policy llq applied. does it need to be replaced with the bandwidth-control policy?
You applied service policy bandwidth-control on outband direction on Fa0/0.10 where packet with destination IP address of 192.168.0.38 should be matched by ACL 105. But this will never happen because packets destinated to 192.168.0.38 are routed out of Se0/0/0 interface.
You need to applied shaping policy on Se0/0/0 interface in outband direction or you need to apply policing on inbound  direction of interface [shaping can not be applied in inbound direction] where are located users which will be shaped. If these users are located on multiple interfaces, only option is to apply shaping on Se0/0/0.
Best Regards
Thanks I'll try that out when I get a chance and let you know how it went.
Thanks again!
Hello
Clase based:
class server_pm
int (lan facing)
CAR
interface (wan)
res
Paul
Thanks.
Kind Regards
Paul
I tried the class based policing, today some users kept connecting/disconnecting from outlook. Is this common?
Hello
at the end of your policy map apply a
class class-default
and try an acl that permits all
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
