10-26-2022 12:45 AM
Hello guys, looking for some references.
currently my network have 2 different ISP. 1 as a main link and the other as the backup if the main link goes down.
I've tested 2 times by shutdown the main link and ping to the loopback address from outside network to check whether the failover works or not, and luckily it does work.
the 1st attempt it takes around 8 sec to switch to the backup link.
the 2nd attempt it takes around 12 sec to switch to the backup link.
Is it possible to shorten the time span to switch to the backup link? or even better if there are no time out when the main link goes down.
heres the topology
here's my configuration, device used is cisco asr1001-x
interface Loopback1
ip address 198.51.101.240 255.255.255.255
interface GigabitEthernet0/0/0.123
description INP-FO-ISAT
encapsulation dot1Q 123
ip address 114.5.179.150 255.255.255.252
interface GigabitEthernet0/0/0.155
description INIX-FO-ISAT
encapsulation dot1Q 155
ip address 124.195.39.226 255.255.254.0
interface GigabitEthernet0/0/1.144
description INIX-RADIO-RADMILLA
encapsulation dot1Q 144
ip address 103.158.98.150 255.255.255.252
interface GigabitEthernet0/0/1.321
description INP-RADIO-RADMILLA
encapsulation dot1Q 321
ip address 103.158.98.146 255.255.255.252
interface GigabitEthernet0/0/2
description TO-FIREWALL
ip address 10.200.0.1 255.255.255.252
negotiation auto
router bgp 149176
bgp log-neighbor-changes
neighbor 103.158.98.145 remote-as 141125
neighbor 103.158.98.149 remote-as 141125
neighbor 114.5.179.149 remote-as 4761
neighbor 124.195.38.1 remote-as 17922
neighbor 124.195.39.1 remote-as 17922
address-family ipv4
network 103.158.98.144 mask 255.255.255.252
network 103.158.98.148 mask 255.255.255.252
network 114.5.179.148 mask 255.255.255.252
network 124.195.38.0 mask 255.255.254.0
network 198.51.101.0
redistribute static
neighbor 103.158.98.145 activate
neighbor 103.158.98.145 soft-reconfiguration inbound
neighbor 103.158.98.145 route-map RADM-INIX-TO-ITB-AJW in
neighbor 103.158.98.145 route-map RADM-INIX-PREPEND-ITB-AJW-OUT out
neighbor 103.158.98.149 activate
neighbor 103.158.98.149 soft-reconfiguration inbound
neighbor 103.158.98.149 route-map RADM-INP-TO-ITB-AJW in
neighbor 103.158.98.149 route-map RADM-INP-ITB-AJW-OUT out
neighbor 114.5.179.149 activate
neighbor 114.5.179.149 soft-reconfiguration inbound
neighbor 114.5.179.149 route-map INP-TO-ITB-AJW in
neighbor 114.5.179.149 route-map INP-ITB-AJW-OUT out
neighbor 124.195.38.1 activate
neighbor 124.195.38.1 soft-reconfiguration inbound
neighbor 124.195.38.1 route-map INIX-TO-ITB-AJW in
neighbor 124.195.38.1 route-map INIX-PREPEND-ITB-AJW-OUT out
neighbor 124.195.39.1 activate
neighbor 124.195.39.1 soft-reconfiguration inbound
neighbor 124.195.39.1 route-map INIX-TO-ITB-AJW in
neighbor 124.195.39.1 route-map INIX-PREPEND-ITB-AJW-OUT out
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 103.158.98.145 50
ip route 10.200.0.0 255.255.0.0 10.200.0.2
ip route 198.51.101.0 255.255.255.0 10.200.0.2
ip prefix-list DEFAULT-ROUTE seq 5 permit 0.0.0.0/0
ip prefix-list DENY-ALL seq 5 deny 0.0.0.0/0 le 32
ip prefix-list ITB-AJW-ROUTE seq 10 permit 198.51.101.0/24
access-list 1 permit 167.205.23.29
access-list 1 permit 167.205.23.19
access-list 1 permit 167.205.1.247
route-map RADM-INP-ITB-AJW-OUT permit 10
match ip address prefix-list ITB-AJW-ROUTE
set as-path prepend 149176 149176 149176 149176
route-map INIX-PREPEND-ITB-AJW-OUT permit 10
route-map RADM-INIX-TO-ITB-AJW permit 10
set local-preference 300
route-map INIX-TO-ITB-AJW permit 10
set local-preference 500
route-map RADM-INIX-PREPEND-ITB-AJW-OUT permit 10
set as-path prepend 149176 149176 149176 149176 149176 149176
route-map INP-ITB-AJW-OUT permit 10
route-map RADM-INP-TO-ITB-AJW permit 10
route-map INP-TO-ITB-AJW permit 10
match ip address prefix-list DEFAULT-ROUTE
!Thanks!
10-26-2022 01:06 AM
you might want to look into BFD for BGP ('neighbor ip-address fall-over bfd'). See the link attached below.
Configuring BFD Support for BGP
10-26-2022 06:12 PM
Hi Georg,
thanks for the input, so the bfd configuration only need to be applied on my router and ISP1 (main link) or need to applied on ISP2 (backup link) too?
10-26-2022 01:18 AM - edited 10-26-2022 01:19 AM
Hello
Next hop tracking and fast failover is enabled by default for (ibgp/ebgp peering ) which should negate the need for the hold timer to be reached before a direct peering is torn down, but if you wish a faster failover you could decrease those bgp timers or append an independent detection feature such as BFD which is similar to fast failover but is also to non-directly connected ebgp peering
Example
bfd-template BFD
interval min-tx 500 min-rx 500 multiplier 5
< min-tx -rx> = trasmit interval values between the BFD packets
< multiplier x > = value of how many packets are require to be missed before peering is deemed unavailble
int x/x
bfd template BFD
or
int x/x
bfd interval min-tx 500 min-rx 500 multiplier 5
router bgp xxx
neighbor x.x.x.x fall-over bfd
10-26-2022 01:22 AM
Hello
Example
bfd-template BFD
int x/x
bfd template BFD
or
int x/x
router bgp xxx
10-26-2022 06:14 PM
Hi Paul,
