ā02-20-2012 04:37 AM - edited ā03-04-2019 03:21 PM
show bfd neighbors details
what the min/max/avg means? (I assume this is the delay between two bfd peers)
I was not able to find cisco document that explain the: show bfd neighbors details
Rx Count: 51505568, Rx Interval (ms) min/max/avg: 1/250/90 last: 20 ms ago
Tx Count: 51511863, Tx Interval (ms) min/max/avg: 1/252/90 last: 8 ms ago
ā02-20-2012 06:53 AM
Those counts are basically the control packets transmitted and received in 8ms and 20ms respectively.
ā02-20-2012 07:06 AM
Thanks for your reply. Do you know any document that explains these values?
If BFD is configured as below:
BFD interval 100 min_rx 100 multi 3
Show BFD detail:
Based on the max value, at least two consecutive BFD packets are lost. IĀ“m not sure if this is correct? IĀ“m not able to find document that explain those values.
