show controllers "transmit ring"
Jasonch518_2
I am having some trouble with a T1 between a Cisco 1721 router with a WIC-1T and a remote T1 router.
The provider is saying that everything is fine, but the show controller outpout looks strange, and I was looking to get some feedback on the "tranmit ring" section and what it indicates.
Interface Serial1
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x8173A68C, driver data structure at 0x81742428
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0300, Mask [SCCM]=0x001F, Status [SCCS]=0x03
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00365F80, Pending [CIPR]=0x04008800
Mask [CIMR]=0x60204400, In-srv [CISR]=0x00000000
Command register [CR]=0x640
Port A [PADIR]=0x0000, [PAPAR]=0x0F0F
[PAODR]=0x0000, [PADAT]=0xE1FF
Port B [PBDIR]=0x0380F, [PBPAR]=0x0C00E
[PBODR]=0x00000, [PBDAT]=0x3075C
Port C [PCDIR]=0x008, [PCPAR]=0x000
[PCSO]=0x0A0, [PCDAT]=0xFC6, [PCINT]=0x000
Receive Ring
rmd(FF002530): status 9000 length 60C address 3819D04
rmd(FF002538): status 9000 length 60C address 3817C84
rmd(FF002540): status 9000 length 60C address 3815584
rmd(FF002548): status 9000 length 60C address 381AA04
rmd(FF002550): status 9000 length 60C address 3813B84
rmd(FF002558): status 9000 length 60C address 3816284
rmd(FF002560): status 9000 length 60C address 3813504
rmd(FF002568): status 9000 length 60C address 3816904
rmd(FF002570): status 9000 length 60C address 381A384
rmd(FF002578): status 9000 length 60C address 3818984
rmd(FF002580): status 9000 length 60C address 3814204
rmd(FF002588): status 9000 length 60C address 3811B04
rmd(FF002590): status 9000 length 60C address 3814884
rmd(FF002598): status 9000 length 60C address 3819684
rmd(FF0025A0): status 9000 length 60C address 3812E84
rmd(FF0025A8): status B000 length 60C address 3816F84
Transmit Ring
tmd(FF0025B0): status 0 length 2C address 0
tmd(FF0025B8): status 0 length 2C address 0
tmd(FF0025C0): status 0 length 34 address 0
tmd(FF0025C8): status 0 length 2C address 0
tmd(FF0025D0): status 0 length 5E0 address 0
tmd(FF0025D8): status 0 length 5E0 address 0
tmd(FF0025E0): status 0 length 5E0 address 0
tmd(FF0025E8): status 0 length 5E0 address 0
tmd(FF0025F0): status 0 length 2E address 0
tmd(FF0025F8): status 0 length 2C address 0
tmd(FF002600): status 0 length 2C address 0
tmd(FF002608): status 0 length 5E0 address 0
tmd(FF002610): status 0 length 5E0 address 0
tmd(FF002618): status 0 length 5E0 address 0
tmd(FF002620): status 0 length 5E0 address 0
tmd(FF002628): status 2000 length 2E address 0
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0xFF003D00)
Rx BD Base [RBASE]=0x2530, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x25B0, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x0, BD Ptr [RBPTR]=0x2530
Tx State [TSTATE]=0x0, BD Ptr [TBPTR]=0x25B0
SCC HDLC PARAMETER RAM (at 0xFF003D38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=1585
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
17835 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
Peter Paluch
Jason,
Can you perhaps be more specific about the problems you are currently having with that interface?
Best regards,
Peter
Sure,
The problem was that we could not get the interface to come up.
We actually ended up re-seating the WIC, which fixed the issue, oddly enough, since it seemed to be in just fine.
I was really just wondering what information can be identified from the transmit and receive ring data.
Thanks for the reply.
