show crypto isakmp sa empty
umbernaut
I can ping and NAT is working.  I've built the phase 1 and 2, the ACL several times using access-list and ip access-list extended and double-checked both routers.
Other than that, "show crypto isakmp sa" just gives:
"IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status"
And "sh cry ipsec sa peer [ip]" is also returning nothing.
I'm stumped.  Any suggestions?
Here is the new routers vpn config, mirrored/reversed on the other:
crypto isakmp policy 5
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key [key] address [other routers public ip]
crypto ipsec transform-set [name] esp-3des esp-sha-hmac
crypto map [name] 10 ipsec-isakmp
set peer [other routers public ip]
set transform-set [name]
match address [name]
ip access-list extended [name]
permit ip 172.16.31.0 0.0.0.31 192.168.17.0 0.0.0.255
8 Replies 8
Muhammed AKYUZ
can you ping the other router?
Yes.  I can ping both routers from each other by their outside interfaces/public IPs.  The existing router is a 2811 and houses 2 working VPN tunnels atm, both working fine.  It is doing NAT just fine too.
The new router is an 1811 and all is good including NAT (I have a laptop hooked to a switch, then the to the 1811 and it NATs good and pings google.com.
I simply cannot get the VPN tunnel to work at all.
I don't see the crypto map applied to any interface and do you exempt traffic going through the tunnel from being natted?
Alain.
Here are the interfaces on the 1811:
interface FastEthernet0
ip address [public ip] 255.255.255.240
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map [name]
interface FastEthernet1
ip address 172.16.31.5 255.255.255.224
ip nat inside
ip nat enable
duplex auto
speed auto
Here are the access lists and NAT:
ip nat inside source list 110 interface FastEthernet0 overload
access-list 110 deny   ip 172.16.31.0 0.0.0.31 192.168.17.0 0.0.0.255
access-list 110 permit ip 172.16.31.0 0.0.0.31 any
Update:
Before giving that last reply, I had the deny below the permit in access-list 110.  I reversed it, and now I get this with "show crypto isakmp sa":
1811#show crypto isakmp sa
[2811publicip]   [1811publicip]    QM_IDLE           2001    0 ACTIVE
The 2811 shows the reverse.  So good so far, but I'm still not getting a reply with ping from either router or the laptop.
so phase 1 is ok, that's a great news.
Now what does sh crypto ipsec sa tells?
Can you do a debug crypto ipsec sa while you are doing your ping and tell us what ping you are doing
Alain.
Ok, I just now got back on this.  I am now able to ping the 2811's inside int from the 1811 via the tunnel.  I had to redo access-list 110 and put the deny up above the permits:
access-list 110 deny   ip 192.168.17.0 0.0.0.255 172.16.31.0 0.0.0.31
access-list 110 permit ip 192.168.17.0 0.0.0.255 any
access-list 110 permit ip 172.16.8.0 0.0.0.255 any
It was like this:
Once I did that, pinging from the laptop to the 2811's inside int (192.168.17.22) started working, and the 2 routers could ping each other's inside int.
The problem now is that I cannot ping any other IP on the 192.168.17.0/24 network from anything on the 172.16.31.0/31 network.  BUT the opposite way, I can ping the laptop, the router and the switch from the 192.168.17.0/24 side.
I'm sure this is an access-list, but I cannot figure it out.
Any thoughts?
What is working and not working?
what is debug crypto ipsec is telling?
Alain
