Show ip traffic output - Frags: section
Daniel Larsson
Some of you might recognize me from CLN but I am trying to learn to use the right sources for the right purposes.
Hopefully someone can link to a document that explains the output of "show ip traffic". Most of it is pretty easy to figure out and some pieces i've already dug up information about (officially). But the "frags/drop-section" is where i lack documentation.
So is there a document somewhere that can explain the entire output? Or perhaps someone that can spare the time to do so? I'll just drop an example output below. It's mainly the Frags/Drops section that needs explanations.
IP statistics:
Rcvd: 5051643 total, 6020930 local destination
0 format errors, 0 checksum errors, 388041 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other, 0 ignored
Frags: 0 reassembled, 18656 timeouts, 0 couldn't reassemble
52 fragmented, 144 fragments, 0 couldn't fragment
0 invalid hole
Bcast: 4589479 received, 4054 sent
Mcast: 1245183 received, 428978 sent
Sent: 2001514 generated, 1056397549 forwarded
Drop: 1865 encapsulation failed, 0 unresolved, 209525590 no adjacency
188 no route, 0 unicast RPF, 0 forced drop, 0 unsupported-addr
0 options denied, 0 source IP address zero
Thanks in advance!
P.s - I know the command is available on multiple platforms.
Hi Daniel,
Did you have any luck finding additional information? Would be good to have a description of each field and a recommended action based on the value.
Dillon
