show route-map
DARYLE DIANIS
If I have a route-map that is configured correctly, shouldn't I see packets and bytes increasing when I do a show route-map command?  This is what I see on all my route maps and I wonder if they are even working.
Policy routing matches: 0 packets, 0 bytes
Nagendra Kumar Nainar
What platform is it?> Can you share the config?.
Hi thanks for helping out.
This is a 7204, running c7200-adventerprisek9-mz.152-4.M2.bin
Here are the eigrp and bgp sections, I removed a few statements, and also the show route-map commands.  The show commands say 0 packets, 0 bytes, so I'm wondering if these route maps are correct?
rtr1#sho run | s r b
router bgp 65002
 bgp log-neighbor-changes
 redistribute static
 redistribute eigrp 1 route-map EIGRP2BGP
rtr1#sho route-map EIGRP2BGP
route-map EIGRP2BGP, deny, sequence 10
  Match clauses:
     tag 10
  Set clauses:
route-map EIGRP2BGP, permit, sequence 20
  Match clauses:
    ip address (access-lists): ALL
  Set clauses:
rtr1#
rtr1#sho run | s r e
router eigrp 1
 redistribute bgp 65002 route-map BGP2EIGRP
 redistribute static metric 1500 0 255 1 1500
 passive-interface Loopback0
rtr1#
rtr1#sho route-map BGP2EIGRP
route-map BGP2EIGRP, deny, sequence 5
  Match clauses:
    ip address prefix-lists: novoip_plist
  Set clauses:
route-map BGP2EIGRP, permit, sequence 10
  Match clauses:
  Set clauses:
    metric 200000 100 255 1 1500
    tag 10
rtr1#
What you see is expected behaviour. packet matches will be seen only when you use it for policy based routing. In this case you use the route-map to match the prefix and redistribute which is at control plane.
-Nagendra
