Showing individual switch log (uptime) of 3750 stack?
mmertens
I have a 3750 stack and see where one of the switches drops out and comes back into the stack every couple days. "Show version" shows the stack system uptime and "show log" doesn't really indicate why the switch left the stack. Is there a way to puruse an individual switch log or do a "show version" on an individual switch to see the reason for restart for a specific switch?
THANKS!
Rick Morris
Level 6
Level 6
It has been some time since dealing with the 3750 so I may be a bit off.
Router#>sh ver | i switch <#>
True example:
Router#>sh ver | i switch 2
I belive this will give you the specific info on the switch in the stack you want. If it is switch 3 then use the number 3 in place of the 2.
Here is a link to some cisco docs that might help:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swstack.html#wp1170763
Rick Morris
Level 6
Level 6
You could also try:
sh switch detail
