Siebel-client bandwidth consumption over WAN
remi-reszka
What's the bandwidth needed for around 20 clients connecting to a main site to the Siebel server or what's the bandwidth needed per single siebel client connection? So far I found in the documentations around 56kpbs per connection should be ok but isn't that too much per single connection? Thanks
vmiller
Level 7
Level 7
Actually that might be low. Siebel tends to be chatty anyway. It is a
good start. What I would do is get a good "before" picture of the Wan links
involved, see if its possible to run 1 client to capture the net effect.
