Signal Strength of Cisco Aironet 1140
bjornwater
We are students from the university HVA of Amsterdam in Holland. We are busy with an ICT project, and we would know some information that would help us to complete our project.
In our project we are building a smartphone application dat determines the locations of persons in a building, using Wifi access points.
Using 3 accespoint we are calculating the overlap of 3 circles.
Today we measured the signal strength and found out that it changes around alot.
So we dont really know if our measurements are right.
We would like to know what the RSSI strengths are of the following access point per meter.
Cisco Aironet 1140 2.4 ghz
With kind regards,
Bjorn Water
hobbe
Level 7
Level 7
Its not the answer to the question that you asked for but it might help. I know there are or atleast was a project where cisco through accesspoints could tell you where equipment where by locating them with the access-points.
Good luck
