Simple 871W Config
Hi all,
I have an old 871W that i am using to learn on. Having an issue where I can connect to the wifi but get no internet. I'm assuming NAT is the issue but it could be something else. If you could point me in the right direction, I would appreciate. THANKS
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ROUTER
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
aaa new-model
aaa authentication login default local
aaa authentication login local_auth local
aaa authorization exec default local
aaa session-id common
resource policy
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp pool EXTERNAL
import all
network 10.0.0.0 255.255.255.0
dns-server 10.0.0.1
default-router 10.0.0.1
domain-name EXTERNAL
ip dhcp pool INTERNAL
import all
network 192.168.2.0 255.255.255.0
dns-server 192.168.2.1
default-router 192.168.2.1
domain-name INTERNAL
no ip bootp server
no ip domain lookup
ip domain name GROUP
crypto pki trustpoint TP-self-signed-2033969614
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2033969614
revocation-check none
rsakeypair TP-self-signed-2033969614
crypto pki certificate chain TP-self-signed-2033969614
certificate self-signed 01
30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32303333 39363936 3134301E 170D3038 30343133 31353233
31325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30333339
36393631 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B244 BF7A047C 7220695A DDE5F370 2C344474 F5206604 A5FDCA28 28301A4A
4CE5D338 60EBB4A2 9E0D6AB1 87362F81 73AA8AFA CB181A11 F20C5528 95022563
A3E42A20 D78E9993 FB396E0E 77188AC7 E0E57BDB 422E0494 3FEC45EC 9C468CF9
19E2D254 51D1F4ED ECF0B384 237DDB57 35967171 E5CBB57F 57B79149 F5F0746C
E1490203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
551D1104 0F300D82 0B4D4154 454F2E4D 4154454F 301F0603 551D2304 18301680
14F7AE10 D300E5AB 7F09D6E8 E58562AD D6EEB368 00301D06 03551D0E 04160414
F7AE10D3 00E5AB7F 09D6E8E5 8562ADD6 EEB36800 300D0609 2A864886 F70D0101
04050003 81810022 E2B01A6B DBCAC039 225B29E0 5799AD10 A8CA083C BDB53262
5B9B0F6D 84B28D6B 2BE2035A 914414F4 B1B80CB0 6E4FF022 49F1569C B8F1B16A
6C680858 B39523F7 DA270952 845A3552 3C4239AE 45C3445E F4F2BA78 F27D0E10
C4E9EFFB A2520D8F 4107DD2D 609E0B7B FCB98773 675B2382 1830EA62 90C65B5F
1BF556EB 3DA921
quit
username admin privilege 15 password 7 03304902080635551C5F
bridge irb
interface FastEthernet0
switchport access vlan 20
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encryption vlan 10 mode ciphers tkip
encryption vlan 20 mode ciphers tkip
ssid External
vlan 10
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 14230002020D3E32767E
ssid Internal
vlan 20
authentication open
wpa-psk ascii 7 107A1B100B1E06125E52
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 5 4.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 10 native
ip access-group EXTERNAL out
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 20
ip access-group INTERNAL out
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
no ip address
interface Vlan10
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Vlan20
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 2
interface BVI1
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface BVI2
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip dns server
ip http server
ip http secure-server
ip nat inside source list 101 interface FastEthernet4 overload
ip nat inside source list 102 interface FastEthernet4 overload
ip access-list extended External
permit ip any any
deny ip 192.168.2.0 0.0.0.255 any
ip access-list extended Internal
permit ip any any
deny ip 10.0.0.0 0.0.0.255 any
access-list 100 permit udp any any eq bootpc
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
line con 0
password 7 0127140D55021216731A
no modem enable
line aux 0
line vty 0 4
password 7 073B334540000D1C4544
scheduler max-task-time 5000
end
make the changes/additions marked in bold to your configuration.
version 12.4
no service pad
hostname ROUTER
boot-start-marker
boot-end-marker
aaa new-model
resource policy
ip subnet-zero
no ip source-route
ip cef
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 192.168.2.1
import all
dns-server 8.8.8.8
import all
dns-server 8.8.8.8
no ip bootp server
no ip domain lookup
1BF556EB 3DA921
quit
bridge irb
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
speed auto
full-duplex
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ssid External
vlan 10
authentication open
guest-mode
ssid Internal
vlan 20
authentication open
station-role root
no cdp enable
bridge-group 1
no cdp enable
bridge-group 2
interface Vlan1
no ip address
interface Vlan10
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Vlan20
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 2
interface BVI1
ip nat inside
interface BVI2
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
ip dns server
ip http server
ip nat inside source list 1 interface FastEthernet4 overload
permit ip any any
permit ip any any
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
no cdp run
control-plane
bridge 1 route ip
bridge 2 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
end
Hello
Change the unicast reverse path forwarding to loose mode without the acl 100 and add the dhcp option to you default static route, Then test again
ip verify unicast source reachable-via any allow-default
Kind Regards
Paul
I am still not able to get out to internet.
Any more help would be appreciated.
Thanks!
boot-start-marker
boot-end-marker
aaa new-model
resource policy
clock timezone CST -6
clock summer-time CDT recurring
ip subnet-zero
no ip source-route
ip cef
import all
dns-server 8.8.8.8
import all
dns-server 8.8.8.8
no ip bootp server
no ip domain lookup
ip domain name MATEO
1BF556EB 3DA921
quit
bridge irb
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
speed auto
full-duplex
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ssid External
vlan 10
authentication open
guest-mode
ssid Internal
vlan 20
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
no cdp enable
bridge-group 2
interface Vlan1
no ip address
interface Vlan10
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Vlan20
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 2
interface BVI1
ip nat inside
interface BVI2
ip nat inside
ip classless
ip dns server
ip http server
permit ip any any
permit ip any any
no cdp run
control-plane
bridge 1 route ip
bridge 2 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
end
I have simplified your configuration, important parts are marked in bold, see if you get it to work this way. The assumption is that the wireless is connected to FastEthernet0. I have taken out all access lists except access list 1, which is used for NAT.
Make sure Vlan 10 and Vlan 20 exist on your router (sh vlan), otherwise globally create them:
871W#conf t
871W(config)#vlan 10
871W(config-vlan)#exit
871W(config)#vlan 20
871W(config-vlan)#end
boot-start-marker
boot-end-marker
aaa new-model
resource policy
ip subnet-zero
no ip source-route
ip cef
import all
dns-server 8.8.8.8
import all
dns-server 8.8.8.8
no ip bootp server
no ip domain lookup
1BF556EB 3DA921
quit
bridge irb
switchport mode trunk
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
speed auto
full-duplex
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ssid External
vlan 10
authentication open
guest-mode
ssid Internal
vlan 20
authentication open
station-role root
no cdp enable
bridge-group 1
no cdp enable
bridge-group 2
interface Vlan1
no ip address
interface Vlan10
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Vlan20
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 2
interface BVI1
ip nat inside
interface BVI2
ip nat inside
ip classless
ip dns server
ip http server
no cdp run
control-plane
bridge 1 route ip
bridge 2 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
end
