simple copy run tftp: (problem on vrf)
cfajardo1_2
objective;
copy active devices config thru TFTP from a remote PC
scenario;
pc----6500lanA--sdh ring 1.....6500lanG
6500lanJ----sdh ring 2---6500lanZ
- lanA 192.168.1.x on vrf
- lanZ 10.10.10.x not on vrf
- there are core switches on each of the major locations of th sdh rings
findings
- we can ping/telnet from the pc to the 6500lanZ loopback (normal ping)
- we cannot ping the pc from the 6500lanZ (normal ping)
- we can ping the pc from the 6500lanZ (vrf ping). ex. ping vrf vrfname 192.168.1.x
- invoking copy run tftp: and just putting the ip of the pc will result in a timeout because the 6500 cant reach the pc
question;
- how copy run tftp will work in this case (if ping vrf is working, then there must be something to make tftp as well)
thanks
Try the "ip tftp source-interface" global configuration command and set the loopback interface as source.
