Simple NAT and WAN issue in Packet Tracer
Zelda
Hi guys,
I'm new to Packet Tracer and trying to learn more and more,
I'm stuck with 2 WAN and 2 NAT troubleshooting.
Would you please assist?
Appreciate in advance!
M02@rt37
Hello @Zelda
For TS3.46 WAN, delete
encapsulation ppp
on Router R2 under interface serial 0/0/1
Best regards
6 Replies 6
balaji.bandi
I do not have PT to help you - check below configuration may help you :
https://www.balajibandi.com/?p=1643
BB
Hello
You could possibly tweak the solution suggested by Balaji a little if you desire..
On the NAT rtr - Have the primary default route towards the primary ISP-colt as a conditional default route tracked with ipsla with a low administrative distance and the secondary default route set with a higher admin distance than the primary, this will then by default route all traffic towards that ISP however it will allow you then just to policy base route any specific traffic towards ISP2 from only a single lan sub-interface plus you will have no requirement of any EEM scripting.
no event manager applet COLT_DOWN
no ip sla 20
ip route 0.0.0.0 0.0.0.0 <interface> 172.16.10.1 1 track 1 name ispcolt
ip route 0.0.0.0 0.0.0.0 <interface> 172.16.20.1 10 name ispbt
interface Ethernet0/0.1
no ip policy route-map COLT_PBR
Note: Policy based routing can become asymmetric meaning even if you policy route egress towards an different external path your return traffic may not route back the same way it exited.
Kind Regards
Paul
M02@rt37
Hello @Zelda
For TS3.4A and B NAT add the Gateway On the Server...
After that PC1 can ping this Server
Best regards
M02@rt37
Hello @Zelda
encapsulation ppp
Best regards
M02@rt37
Hello @Zelda
For TS3.6B WAN, delete
encapsulation frame-relay
on Router R1 under interface serial 0/0/0
Do
#show ip int erfacebrief
and check interfaces status
Best regards
Martin L
frame-relay ?  I don't think that WAN tech is still supported and tested on exam; it should be replaced by PPP or HDLC and more likely by PPPoE.
Regards, ML
**Please Rate All Helpful Responses **
