Simple QoS for backup traffic only
maxim_ratinov
We have the follwing task:
Bunch of remote offices on Cisco routers 8XX/17XX running email, office applications etc. Speed to world is 1.5Mbps.
And here we have backup traffic which takes entire channel.
Task is to configure simple QoS which will match destination ip of backup server as lowest possible priority if channel is busy (say 10% of the link speed)
Thanks.
6 Replies 6
Joseph W. Doherty
Not sure those routers support CBWFQ, but if they do, something like:
(NB: syntax might be incorrect)
class-map backuptraffic match-any
match (match an ACL that matches your backup traffic)
policy-map sample
class backuptraffic
bandwidth percent 1
class class-default
fair-queue
interface serial #
service-policy output sample
Backuptraffic class can still utilize 100% link bandwidth, but it will yield bandwidth to other traffic. Effectively, it will only obtain bandwidth otherwise being usused.
Thanks!
But I am in doubt about CBWFQ in this implementation as it will quarantee 1% of bandwidth for backup when I need to guarantee all other traffic rather then backup (last priority).
SO I add some shaping here. Please have a look if it is fine from your perspective
ip access-list extended MATCH_BACKUP
permit ip any host XXX
permit ip any host YYY
permit ip any host ZZZ
match access-group MATCH_BACKUP
policy-map USAGE
class backuptraffic
bandwidth percent 1
shape average 100000
shape peak 1544000
class class-default
fair-queue
interface serial #
service-policy output USAGE
Any comments?
No, don't see the need for shaping. Shaping would preclude backup from using bandwidth that's otherwise not being used. If we only guarantee backup 1% it leaves all other traffic 99%. (Actually with FQ in class-default, it's more complex but doubt if we need to get into why.)
If you want, you could guarantee other traffic absolute priority over backup traffic but that's a good way to completely break backup flows if you totally starve them of bandwidth.
Shaping should limit backup traffic, isn't it?
I read here http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfcbshp.html#wpxref80464
So actually what I try to achieve is not to give priority to backup but rather find a simple way to limit it when other types of traffic are present.
I could think about setting priorities for all other traffic but... too different apps and different offices around.
So my question about initial config - if backup traffic will exceed 1% and wan link will be full say with Exchange - who will drop backup or how fighting for bandwidth will be looking like?
"Shaping should limit backup traffic, isn't it? "
Should it? No. Could it? Yes.
"So actually what I try to achieve is not to give priority to backup but rather find a simple way to limit it when other types of traffic are present."
Yes, correct. What I suggested deprioritzes backup traffic relative to other traffic.
"So my question about initial config - if backup traffic will exceed 1% and wan link will be full say with Exchange - who will drop backup or how fighting for bandwidth will be looking like?"
If backup exceeds 1% it's because the bandwidth wasn't otherwise being used. For example, Exchange could use 10% leaving backup 90% or Exchange could use 70% leaving backup 30%. If both backup wanted all 100% and Exchange wanted all 100%, backup would only get 1% and Exchange 99%.
Did you try such QoS implementation? It is interesting as I did tests and it is not working at all. Then I did some more research and found that QoS input should be applied to Eth interface using dscp.
So simple task requires so many time to spend doing reseach.
Cisco has documentation about CBWFQ, but it doesnt work in reality
