Simple query - which router do i need ?
8acdc9441
Hi All. All of the time that i've had broadband, i've always had problems with routers. They always need resetting to revitalise the connection & they usually only last a year or two before they stop working completely.
I've had the ones supplied by the providor (sky,bt etc...) and had several netgear ones too. Cheap ones and expensive ones. They all play up the same.
I want to buy a business/industrial spec rack mount router to use at home, but i don't know which to get.
Incidentally - i want a low cost second hand one to keep the cost down.
My broadband is ADSL2+ and i'd like it to be Gigabit lan and wifi.
From looking at what there is available, it seems to me that you choose the router/switch, then add on a modem and a wifi card.
What do i need to buy ? Model numbers please.
Thanks for your help :-)
8 Replies 8
Leo Laohoo
What is your budget?
I don't want to pay new prices, so as cheap as possible, as long as it'll do the job.
Second hand rack mount routers can be got for as little as £10 so i'd be happy to pay up to around £50 for the setup that i need. Maybe a bit more if need be.
Is that being a bit optimistic ?
£50
£50 for an enterprise-grade DSL router?  I don't think you'll find anything close to this price.  Maybe Linksys (now owned by Belkin) but not Cisco.
As i said in original post - i'm asking for model numbers. When somebody is kind enough to let me know what works with what, i can look into what i can get to suit whatever budget i feel like spending at the time.
It's amazing what bargains can be had on ebay. Absolute bargains :-)
Budget is irrelevant. See original post!
8acdc9441
What i'm asking for is "Model numbers" as requested in original post. So prices and budgets are completely irrelevant.
Model numbers of the lowest cost items to build up a gigabit ADSL2+ wireless router. Rack mountable as i intend to stack other units on top.
That is all :-)
RON ROYSTON
smallest rack mount is 1921.
http://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/data_sheet_c78-598389.html
chrisjohn93
According to your need and requriment I Suggest you, Router 1900 Series
