GRE tunnel causes High CPU IP Input on SM-ES3G-16-P
narendrabimo
I have a problem when i configure GRE tunnel over WAN (MPLS). I configure GRE tunnel between Cisco Catalist 4500 and SM-ES3G-16-P on ISR 3945. At first, there was not any problem at all. But, when traffic is increasing (Voice traffic), link becomes intermittent and CPU on SM-ES3G-16-P is high (68%). the highest cpu proccess is IP Input (>60%). Is there any suggestion for this problem? Thanks
4500 Configuration:
show run int tunnel
interface Tunnel14
 bandwidth 1000000
 ip address 172.29.1.6 255.255.255.252
 ip mtu 1400
 ip tcp adjust-mss 1360
 delay 1
 tunnel source GigabitEthernet2/3
 tunnel destination 10.10.100.254
show int tunnel
Tunnel14 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 172.29.1.6/30
  MTU 17900 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 172.16.21.194 (GigabitEthernet2/3), destination 10.10.100.254
   Tunnel Subblocks:
      src-track:
         Tunnel14 source tracking subblock associated with GigabitEthernet2/3
          Set of tunnels with source GigabitEthernet2/3, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:01, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute output rate 95000 bits/sec, 114 packets/sec
     15504389 packets input, 7190678105 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     104453835 packets output, 14200412300 bytes, 0 underruns
     0 unknown protocol drops
SM-ES3G-16-P Configuration:
show run int tunnel
interface Tunnel14
 bandwidth 1000000
 ip address 172.29.1.5 255.255.255.252
 ip mtu 1400
 delay 1
 tunnel source 10.10.100.254
 tunnel destination 172.16.21.194
end
show int tunnel
  Hardware is Tunnel
  Internet address is 172.29.1.5/30
  MTU 17916 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Tunnel source 10.10.100.254, destination 172.16.21.194
  Last input 00:00:00, output 00:00:07, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1997
     99312017 packets input, 13601218040 bytes, 0 no buffer
     15507171 packets output, 7194871509 bytes, 0 underruns
Charles Hill
What is the iOS?
Hi Charles,
4500 IOS version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.03.02.SG RELEASE SOFTWARE (fc1)
license: ipbase
SM-ES3G-16-P
SM-ES3G-16-P version
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(52)EX1, RELEASE SOFTWARE (fc1)
license: ipservices
There is an Ask the Expert: High CPU on IOS in the LAN, Switching and Routing section, perhaps a great opportunity for such a question!
As you know, one characteristic of voice traffic is that you have many very small packets. The router, in your case a software-based ISR, has to encapsulate every single packet (GRE- and new IP-header). Of course there are limitations, unfortunately it appears to be impossible to find any official recommendations on that.
So again, you may want to ask this question at the Ask-the-Expert event, I believe Vinit Jain could provide with some very valuable information.
Rolf
Hi Rolf,
Thank you for your advise, i am looking forward to join the Ask-the-Expert event.
