Simple routing question - its been a long time...
Huw Davies
Hi guys,
Sorry for such a lame post, its been years since I've had to configure a Cisco device.
I have an Ethernet internet connection presented to me that i'd like to test. I have a useable public address for that connection. I want to connect an old 1841 to it.
I want FE0/0 to have the public IP (and hence the gateway to the interweb)
I want FE0/1 to have an internal IP, and the 1841 to dole out DHCP.
So basically I want all internet traffic to go out via FE0/0.
This is where I've got to, but no joy. I suspect NAT is my issue, its been my arch enemy.
Can you point out where i'm going wrong?
Thanks!
version 12.4
hostname Mary_Celeste
boot-start-marker
boot-end-marker
enable secret 5 blablabla
no aaa new-model
resource policy
ip cef
ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.250 255.255.255.0
ip dhcp pool DHCP
   network 192.168.1.0 255.255.255.0
   dns-server 194.150.201.22
   lease 2
controller E1 0/0/0
interface FastEthernet0/0
 ip address 188.111.222.33 255.255.255.224
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.1.250 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
ip nat pool NAT 192.168.1.0 192.168.1.100 netmask 255.255.255.0
ip nat outside source list 1 pool NAT add-route
disable-eadi
control-plane
line con 0
line aux 0
line vty 0 4
 login
scheduler allocate 20000 1000
end
Jon Marshall
If that is your public IP can you blank out the middle octets eg. 188.x.x.33 as this is a public forum.
That aside not sure what the NAT pool is for but for a basic configuration -
1) remove your current NAT configuration
2) add this configuration -
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 101 interface fa0/0 overload
Jon
Jon Marshall
Jon
Jon is quite right that the NAT pool as configured will not work because it would attempt to translate the private address into a private address (and in the same subnet range).
Aside from the NAT issue there may be another aspect to consider which is the default route
At best it is not a good practice and it is quite possible that this default route could cause failure to access the Internet. The issue is that when a static route points just to the exit interface (and the interface is Ethernet) then the router must ARP for every destination address. And it will work only if the next hop router has enabled proxy arp. If the next hop does not enable proxy arp (and increasingly providers are not enabling proxy arp because of security concerns) then the router can not access the Internet. So it would be much better if the default route specified the next hop address rather than just the exit interface.
Rick
Rick
OK Richard i'll alter that thanks
Hi Jon - yep I made that public IP range up.
cheers for the reply i'll give those a go
