Simple Static NAT on Cisco 3850
GeneWilson8589
I have a Cisco 3850.  I have read the discussions on whether or not they do NAT.  It appears people have got them to do so.  I am needing mine to nat between 192.168.125.x(inside) and 10.10.9.x.(outside).  I am needing to be able to hit a device on the inside by going to 10.10.9.101 and reaching 192.168.125.101.  I think i have been close but not been able to get over the hump.  Would appreciate any help.
WTPAB3850#sh runn
Building configuration...
Current configuration : 5075 bytes
! Last configuration change at 14:37:26 UTC Fri Nov 22 2019
version 15.2
no service pad
service password-encryption
service compress-config
hostname WTPAB3850
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$xo4H$EwE.rDc3BRJYNAd9G6ts60
enable password 7 13061F01382F250E0A
username plcadmin privilege 15 password 7 1511031F37090A000972
username gwilson privilege 15 secret 5 $1$rH1W$br98SjTvB7OTx4uQWhZQu.
no aaa new-model
switch 1 provision ws-c3850-24s
no ip domain-lookup
ip domain-name CHS-PLC
qos queue-softmax-multiplier 100
password encryption aes
crypto pki trustpoint TP-self-signed-289714166
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-289714166
revocation-check none
rsakeypair TP-self-signed-289714166
crypto pki certificate chain TP-self-signed-289714166
certificate self-signed 02
30820229 30820192 A0030201 02020102 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32383937 31343136 36301E17 0D313931 31313531 39303135
355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3238 39373134
31363630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
DE2B3B1F D27A85D1 58969F00 C5EC8A67 0EB9016E 9B9F6895 5993541D 4047941D
6707268E 10A9534C F486805B E754E3E0 73C972AA 1B538060 2DF312E4 CBB3BA89
3EF12651 27205D01 95330B72 ACD41BFD F088A845 011651A4 216F3770 2175DD70
3005CEAA 7B256852 525694BF D588AB57 23619FB9 0F75AD18 FE7FD70F D656E939
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 168014AA 4CB98932 C715DEE1 10A5F756 86F8F8EB AEBAA030 1D060355
1D0E0416 0414AA4C B98932C7 15DEE110 A5F75686 F8F8EBAE BAA0300D 06092A86
4886F70D 01010505 00038181 00410982 A51EB8A4 D8E25264 F7DD30D2 48520A1A
69A45B91 4C08E00A 31993C87 7B313549 3135F43E CBE03236 A451C130 5A0D07CC
553A91D2 40231B38 39B522AE DDE29B7A 14FAAF10 6BB0F0DB F02EF708 DF48C026
68F9859F DD295CBD D339BDD4 45540A51 B755EB24 67DAA01C 49306839 27377110
09031DEE 74874D30 FDE9D5DF A1
quit
diagnostic bootup level minimal
spanning-tree mode pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/0/1
description BWR_CAB_MOXA
interface GigabitEthernet1/0/2
description CW_CAB_MOXA
interface GigabitEthernet1/0/3
duplex auto
interface GigabitEthernet1/0/4
description CW_I/O
duplex full
interface GigabitEthernet1/0/5
description BWR_I/O
duplex full
interface GigabitEthernet1/0/6
description NF_I/O
duplex full
interface GigabitEthernet1/0/7
duplex auto
interface GigabitEthernet1/0/8
speed nonegotiate
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
description BF
duplex full
interface GigabitEthernet1/0/11
duplex auto
interface GigabitEthernet1/0/12
duplex auto
interface GigabitEthernet1/0/13
description RO
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
description WAN
switchport access vlan 2
switchport mode access
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
ip address 192.168.125.246 255.255.255.0
ip nat inside
interface Vlan2
ip address 10.10.9.254 255.255.255.0
ip nat outside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
line con 0
logging synchronous
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 03075318352C00686F48
login local
transport input ssh
line vty 5 15
password 7 094F461A2A2636362A4D
login
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
5 Replies 5
Jon Marshall
You don't seem to have a NAT statement  -
"ip nat inside source static 192.168.25.101 10.10.9.101"
it may or may not work because as you say seems to be some debate as to whether NAT is supported and/or works on those switches.
Jon
to add to the 'debate': the 3850 does support NAT if you run an XE release (e.g. 3.07.00E)...
I should of left that as a note as well.  When I try that command it does not accept the "static"  I get invalid input
I think you need to have 'IP Services' installed...can you verify which feature pack you are running (sh lic) ?
Hello
FYI - Nat seems applicable to work on 3850
Image cat3k-caa-universalk9
Sw 03.7.00e
Kind Regards
Paul
