Simple tunneling not working - whats wrong?
amarranca
Well, I'm trying to make a tunnel between a WiFi hotspot ADSL router and another cisco router. I try to open the tunnel but I receive "% Connection refused by remote host"
Below is my config, where have I gone wrong?
*** WiFi ADSL Cisco 827 Router ***
interface Tunnel99
description *** tunnel to 831 router ***
no ip address
tunnel source BVI1
tunnel destination X.X.17.103
interface Ethernet0
description outbound for WiFi users
ip address 10.0.10.1 255.255.255.0
ip nat inside
no cdp enable
hold-queue 100 out
interface BVI1
ip address X.X.19.130 255.255.255.224
ip nat outside
ip nat inside source list 102 interface BVI1 overload
ip nat inside source static tcp 10.0.10.5 80 interface BVI1 80
ip classless
ip route 0.0.0.0 0.0.0.0 BVI1
no ip http server
*** End Cisco 831 Router ***
interface Tunnel99
description *** Tunnel to 827 Router ***
no ip address
keepalive 10 3
tunnel source Ethernet1
tunnel destination X.X.19.130
interface Ethernet1
ip address X.X.17.103 255.255.255.0
duplex auto
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.17.1
ip route X.X.19.128 255.255.255.224 Tunnel99
15 Replies 15
Ok everyone, thank you so much for your replies. Here is the status of my tunneling problem:
I have good connectivity from tunnel to tunnel
I can ping all the way across. From my Hotspot router I can reach 10.250.0.2 which is the IP on E0 of the AirMarshall Router.
I have two questions:
#1 - When I do a traceroute from a client machine BEHIND the HotSpot router it doesnt FORCE my traffic to go thru the tunnel. If I traceroute to yahoo.com I dont even hit the tunnel. If I traceroute to 10.250.0.2 I have a successful route and my last IP I hit is 192.168.200.10 (the tunnel IP on the AirMarshal Router)I cant go any further.
#2 - I want to force all traffic from E0 of the AirMarshall router to 10.250.0.1. The easiest way is thru Policy Based Routing correct? My source interface being E0 and next-hop being 10.250.0.1 correct? Would my match IP access-list be the IP coming thru the tunnel 10.250.10.X or something else?
Attached are copies of my updated config
Do I need to have FastEthernet1 configured differently for AirMarshall?
(See Attahced Log)
