03-19-2014 03:48 AM - edited 03-04-2019 10:36 PM
Hi.
have 2911 with ISP DSL link and fiber. 2 DMVPN tunnels with these source. For those was created 2 VRF.
Now have need to establish BGP session to neighbor which is located behind the fiber (GE 0/0 int). Need to export route from vrf to global.
interface ATM0/0/0
ip vrf forwarding vrf1
no ip address
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Dialer1
interface GigabitEthernet0/0
description Fiber
ip vrf forwarding vrf2
ip address 172.30.149.2 255.255.255.252
duplex auto
speed auto
no cdp enable
router bgp 65149
bgp router-id 172.30.149.2
bgp log-neighbor-changes
network 172.30.149.0 mask 255.255.255.252
neighbor 172.30.149.1 remote-as 65149
ip route 172.30.149.0 255.255.255.252 GigabitEthernet0/0
ip route vrf vrf1 0.0.0.0 0.0.0.0 Dialer1
ip route vrf vrf2 0.0.0.0 0.0.0.0 172.30.149.1 - next hop is behind the GigabitEthernet0/0
I have tring this http://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/multiprotocol-label-switching-vpns-mpls-vpns/47807-routeleaking.html#global
to add a static route
sh ip route vrf vrf2
Gateway of last resort is 172.30.149.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 172.30.149.1
172.30.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.30.149.0/30 is directly connected, GigabitEthernet0/0
L 172.30.149.2/32 is directly connected, GigabitEthernet0/0
static route is added successfully
sh ip route
S 172.30.149.0/30 is directly connected, GigabitEthernet0/0
but ping wasn't successful. Whats wrong?
Solved! Go to Solution.
03-21-2014 04:47 AM
Hello
MBGP requrie the use of address family identifiers - can you try this?
no router bgp 65149
router bgp 65149
no synchronization
no auto-summary
address-family ipv4 vrf vrf2
neighbor 172.30.149.1 activate
no synchronization
exit-address-family
sh bgp all summary
sh bgp vpnv4 unicast all
res
Paul
03-19-2014 05:42 AM
What were you pinging? Are you sure that whatever you were pinging has a route back to your address?
Rick
03-19-2014 07:01 PM
I have tring to ping IP 172.30.149.1 (that was behind the 172.30.149.0/30 GigabitEthernet0/0, connected directly to that interface) but has no success.
ping IP of interface is ok:
#ping 172.30.149.2
Sending 5, 100-byte ICMP Echos to 172.30.149.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ping 172.30.149.1
Sending 5, 100-byte ICMP Echos to 172.30.149.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
have only 1 static route:
03-20-2014 07:07 AM
Can you post the output of show arp
Rick
03-20-2014 07:15 AM
traceroute might help too. I thought you achieve VRF route leak with route import and exports?
03-20-2014 07:03 PM
import-export and MP-BGP I thought inter-VRF only. BHW I trying this - no success.
I need to route leak from VRF to global.
It is funnu but in this case traceroute is successfull but no ping and no bgp establish from this interface.
03-20-2014 07:01 PM
03-20-2014 07:44 PM
If 172.30.149.1 is an address on a connected interface and if the arp table is empty then that suggests that there is a layer 2 issue with connectivity. If arp request and arp response are not working then there is no way that ping can work.
Rick
03-20-2014 07:01 PM
03-21-2014 04:47 AM
Hello
no router bgp 65149
router bgp 65149
no synchronization
no auto-summary
no synchronization
exit-address-family
sh bgp all summary
res
Paul
03-23-2014 03:33 AM
Yeah! Great! No need to do a route leak. Bgp on vrf is working as well as in 'normal' mode, just a 'show' command looks a slight different.
