Single lease line connecting 2 perimeter router
rkcontrol
Hi all,
I have 2Mb lease line connecting my existing perimeter router, now i want to install a redundant router in this network.
what i want to know is: IS there any device which will connect my single 2Mb lease line connecting to both the Perimeter router.
Raj
ankurbhasin
Level 9
Level 9
HI rkcontrol,
I do not think there is any such device which split your 2 mb link into 2 different links for your 2 routers but I will like to now is your purpose is to have a redundancy for your lan that if one router goes down the lan will flow from 2nd router to same 2 mb link? or your purpose is load sharing on 2 MB link.
If yes I have an idea. Update if it is yes.
Ankur
Thanks Ankur,
This is a perimeter router which connects the LAN to internet.intervlan is happening on C6509.
We want to have redundant perimeter router with Single lease line. Ya we can also consider load balancing using redundant perimeter router.
Raj.
