SITE-2-SITE GRE Tunnel Problem with 7600 in Core Network
shoaib.farhan
We are having a strange issue after deploying 7604 Router in our Network. When we connect our customer to 7604 Router their GRE tunnel never got up. But if we use 7200 router then it is working fine. Here is topology diagram:
CE1==>PE1-SWITCH==>PE1-ROUTER===MPLS CORE NETWORK=====PE2-ROUTER===>PE2-SWITCH====>CE2
Problem is at PE1-ROUTER where 7604 is in use. Tunnel showing UP/Down at CE1 and UP/UP at CE2.
sh module
Mod Ports Card Type                              Model              Serial No.
  1    5  Route Switch Processor 720 10GE (Activ RSP720-3CXL-10GE   JAE144907ZS
  2   11  7600 ES+                               76-ES+XC-20G3CXL   JAE1342LP0L
Mod MAC addresses                       Hw   Fw            Sw           Status
  1  68ef.bdd3.5e20 to 68ef.bdd3.5e27  1.0   12.2(33r)SRD  15.3(3)S     Ok
  2  0024.f94f.1530 to 0024.f94f.154f  1.3   12.2(33r)SRE  15.3(3)S     Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 3       7600-PFC3CXL-10GE  JAE144906SY  1.2    Ok
  1  C7600 MSFC4 Daughterboard   7600-MSFC4         JAE14450XVI  2.2    Ok
  2  7600 ES+ DFC XL             7600-ES+3CXL       JAE131885KB  1.1    Ok
  2  ES+ 1xTGE XFP 10xGE SFP     7600-ES+20C        JAE1343LYS4  1.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
sh version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.3(3)S6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 30-Jul-15 22:35 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD6, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.3(3)S6, RELEASE SOFTWARE (fc1)
DHANMONDI-RTR uptime is 1 week, 6 days, 19 hours, 22 minutes
Uptime for this control processor is 1 week, 6 days, 19 hours, 22 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 13:55:49 BDT Mon Nov 28 2016
System image file is "sup-bootdisk:c7600rsp72043-advipservicesk9-mz.153-3.S6.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7604 (M8500) processor (revision 2.0) with 1900544K/131072K bytes of memory.
Processor board ID FOX11270UFX
 BASEBOARD: RSP720-10GE
 CPU: MPC8548_E, Version: 2.1, (0x80390021)
 CORE: E500, Version: 2.2, (0x80210022)
 CPU:1200MHz, CCB:400MHz, DDR:200MHz,
 L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
13 Gigabit Ethernet interfaces
3 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Debug Output at CE1 with 7604
Dec 11 12:10:57.535: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=252 tos=0x0)
*Dec 11 12:10:57.535: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:10:57.547: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=252 tos=0x0)
*Dec 11 12:10:57.547: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:10:58.231: Tunnel1: sending keepalive, 172.100.50.30->172.100.50.34 (len=24 ttl=255), counter=6
*Dec 11 12:10:58.231: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=48)
*Dec 11 12:10:58.539: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=252 tos=0x0)
*Dec 11 12:10:58.539: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:10:58.551: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=252 tos=0x0)
*Dec 11 12:10:59.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
*Dec 11 12:10:59.539: Tunnel1: GRE/IP classify 172.100.50.30->172.100.50.34 failed, tunnel down
*Dec 11 12:10:59.539: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=74 ttl=252)
*Dec 11 12:10:59.567: Tunnel1: GRE/IP classify 172.100.50.30->172.100.50.34 failed, tunnel down
*Dec 11 12:10:59.567: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=74 ttl=252)
*Dec 11 12:11:00.555: Tunnel1: GRE/IP classify 172.100.50.30->172.100.50.34 failed, tunnel down
*Dec 11 12:11:00.555: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=74 ttl=252)
*Dec 11 12:11:00.587: Tunnel1: GRE/IP classify 172.100.50.30->172.100.50.34 failed, tunnel down
*Dec 11 12:11:00.587: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=74 ttl=252)
*Dec 11 12:11:01.575: Tunnel1: GRE/IP classify 172.100.50.30->172.100.50.34 failed, tunnel down
*Dec 11 12:11:01.575: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=74 ttl=252)
*Dec 11 12:11:01.607: Tunnel1: GRE/IP classify 172.100.50.30->172.100.50.34 failed, tunnel down
*Dec 11 12:11:01.607: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=74 ttl=252)
Debug Output at CE1 with 7200
*Dec 11 12:08:04.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
*Dec 11 12:08:05.051: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:05.051: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:06.059: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:06.059: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:06.079: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:06.079: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:07.059: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:07.059: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:07.079: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:07.079: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:08.059: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:08.059: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:08.079: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:08.079: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:08.231: Tunnel1: sending keepalive, 172.100.50.30->172.100.50.34 (len=24 ttl=255), counter=1
*Dec 11 12:08:08.231: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=48)
*Dec 11 12:08:08.231: Tunnel1: GRE/IP to decaps 172.100.50.30->172.100.50.34 (len=24 ttl=249)
*Dec 11 12:08:08.231: Tunnel1: keepalive received, 172.100.50.30->172.100.50.34 (len=24 ttl=249), resetting counter
*Dec 11 12:08:09.067: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:09.067: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
*Dec 11 12:08:09.079: Tunnel1: GRE/IP to classify 172.100.50.30->172.100.50.34 (len=74 type=0x800 ttl=250 tos=0x0)
*Dec 11 12:08:09.079: Tunnel1: GRE/IP encapsulated 172.100.50.34->172.100.50.30 (linktype=7, len=74)
We use this two command in 7604 but no luck.
mls rate-limit all ttl-failure 70000 150
mls rate-limit all mtu-failure 50000 150
sh mls rate-limit usage
                             Rate Limiter Type     Packets/s   Burst
Layer3 Rate Limiters:
             RL# 0: Free                       -           -       -
             RL# 1: Free                       -           -       -
             RL# 2: Free                       -           -       -
             RL# 3: Used
                                     MTU FAILURE       50000     150
             RL# 4: Used
                                     TTL FAILURE       70000     150
             RL# 5: Used
                                  IP RPF FAILURE         100      10
                           ICMP UNREAC. NO-ROUTE         100      10
                           ICMP UNREAC. ACL-DROP         100      10
                                       IP ERRORS         100      10
             RL# 6: Used
                                    ACL VACL LOG        2000       1
             RL# 7: Used
                                  MCAST DFLT ADJ      100000     100
             RL# 8: Rsvd for capture           -           -       -
Layer2 Rate Limiters:
             RL# 9: Reserved
             RL#10: Reserved
             RL#11: Free                       -           -       -
             RL#12: Free                       -           -       -
sh mls statistics
Statistics for Earl in Module 1
L2 Forwarding Engine
  Total packets Switched                : 14636946657
L3 Forwarding Engine
  Total packets Processed               : 6640024385 @ 1691 pps
  Total packets L3 Switched             : 3097388219 @ 1463 pps
  Total Packets Bridged                 : 3402523472
  Total Packets FIB Switched            : 3097388219
  Total Packets ACL Routed              : 0
  Total Packets Netflow Switched        : 0
  Total Mcast Packets Switched/Routed   : 105330584
  Total ip packets with TOS changed     : 2
  Total ip packets with COS changed     : 2
  Total non ip packets COS changed      : 0
  Total packets dropped by ACL          : 2
  Total packets dropped by Policing     : 0
  Total packets exceeding CIR           : 0
  Total packets exceeding PIR           : 0
Errors
  MAC/IP length inconsistencies         : 0
  Short IP packets received             : 0
  IP header checksum errors             : 0
  No-route packet drops                 : 5601100
  TTL failures                          : 103801
  MTU failures                          : 0
Statistics for Earl in Module 2
  Total packets Switched                : 58230404626
  Total packets Processed               : 52957685770 @ 48401 pps
  Total packets L3 Switched             : 46315161966 @ 45363 pps
  Total Packets Bridged                 : 3565174847
  Total Packets FIB Switched            : 46114733327
  Total Packets ACL Routed              : 200428638
  Total Packets Netflow Switched        : 1
  Total Mcast Packets Switched/Routed   : 320855999
  Total ip packets with TOS changed     : 0
  Total ip packets with COS changed     : 0
  Total packets dropped by ACL          : 3348174
Errors
  MAC/IP length inconsistencies         : 434
  IP header checksum errors             : 272
  No-route packet drops                 : 144096606
  TTL failures                          : 10553306
  MTU failures                          : 6462854
Total packets L3 Processed by all Modules: 59597710155 @ 50092 pps
If someone have any ideas please share with us.
can you post the config of the 7604 ? Which IOS are you running ?
Sorry I missed that you already posted the 'sh ver'. I checked for bugs: do you have any QoS on your tunnel ?
Either way, seeing the configs of both the 7600 and the 7200 could provide a clue.
