Site to research know bugs in Cisco IOS
John Blakley
Where can I find the site that discusses known problems in IOS? I updated to 12.4(24) on a 2811, and we started seeing weird utilization in our monitoring software, but the version before it doesn't do it 12.4(23). The problem is that 12.4(24) supports BGP in IPBase, but 12.4(23) doesn't. I thought there was a site that you could see all of the known problems with current and previous IOS versions.
John
HTH, John *** Please rate all useful posts ***
8 Replies 8
Richard Burts
John
There are several resources that may help you:
- check the release notes for the release, especially the section on open caveats.
- check the Bug Tool Kit you can search in it for bugs in particular releases.
here is the link to the Bug Tool Kit:
http://tools.cisco.com/Support/BugToolKit/
note that you need a registered ID to access this tool.
Rick
Rick
Edison Ortiz
The only public site from Cisco is the following:
http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
You can also see the IOS release notes.
BTW, you can use the 12.4(T) train. BGP on IP Base has been available on the T train for quite some time (beginning with 12.4(11)T, to be exact).
http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TNEWF.html#wp1822285
HTH,
__
Edison.
Edison,
I updated over the weekend to IPBase 12.4(23), and when I try to create the bgp process, we're getting the "protocol not in this image" error.
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 08-Nov-08 21:57 by prod_rel_team
Router(config)#router bgp 33
Protocol not in this image
Router(config)#
Did I miss something?
John
John,
That's 12.4(Mainline). If you want a code other than 12.4(24)T that is somewhat stable, try 12.4(15)T8 which supports BGP on IP Base.
__
Edison.
Ah, I found the T train listed under the 2821 section.
Thanks Edison; I'll give that a shot tonight.
John
BTW, what do you me by "somewhat stable?" Have the 12.4.2xT been unstable in some regard?
John
John
Since the purpose of the T train is to introduce new technologies it is inherently less stable than mainline code.
I have been running 12.4(15)Tx in quite a few routers and it has done well for us.
I am looking at newer versions of code to address some of the recently announced vulnerabilities. But for stability and functionality I believe that 12.4(15)T8 would be good.
Rick
Rick
John,
12.4.(15)Tx is a more mature branch.
__
Edison.
