site to site connectivity between branch and HO
mahesh.katariya
HO router getting ssh request from outside so i want to block the ssh traffic from outside but i want to allow ssh traffic from branch side and tunnel between branch and HO so how to configure ACL on HO router so i block the ssh traffic from outside but branch get ssh access of HO router.
Kindly suggest referance acl configuration
Hello
you could possibly utilise MPP (management plane protection) to specify what interface allows what mgt protocol
example:
conf t
control-plane
management-plane
allow xxx interface xxxx
commit
Kind Regards
Paul
mahesh.katariya
i want to configure acl so how can i configure
i am configuring referance acl as
ip access-list extended ssh_block
permit tcp tunnel_ip of branch WAN_IP_OF_HO eq 22
deny tcp any WAN_IP_HO eq 22
permit ip any any
int eth0/0---> WAN LINk connected on interface
ip access-group ssh_block in
My acl is correct or not ?
Hello
If its internal to the rtr then apply the acl ingress on the physical interface, However if you want to negate ssh directly to the wan rtr itself then apply it to the vty lines.
Lastly your ACL does look correct
Kind Regards
Paul
