Maximum number of ospf instances
starter
Hello everyone,
Does anybody know how many OSPF process ids are supported by catalyst 6807-XL series?
Thank you in advance.
balaji.bandi
I never tested so many (i did not see the requirement) look at the FAQ : ( should be same on Cat 6800 i guess)
Q. What is the maximum number of OSPF processes (VRF aware) on 7600/6500 platforms?
A. Cisco IOS has a limit of 32 routing processes. Two of these are saved for static and directly connected routes. The Cisco 7600 router supports 28 OSPF processes per VRF.
BB
balaji.bandi
BB
Thank you!
